| capacity (defined in Obi.ObiEmitterBlueprintBase) | Obi.ObiEmitterBlueprintBase | |
| GetParticleMass(Oni.SolverParameters.Mode mode) | Obi.ObiEmitterBlueprintBase | |
| GetParticleSize(Oni.SolverParameters.Mode mode) | Obi.ObiEmitterBlueprintBase | |
| Initialize() (defined in Obi.ObiEmitterBlueprintBase) | Obi.ObiEmitterBlueprintBase | protectedvirtual |
| OnValidate() (defined in Obi.ObiGranularEmitterBlueprint) | Obi.ObiGranularEmitterBlueprint | |
| randomness (defined in Obi.ObiGranularEmitterBlueprint) | Obi.ObiGranularEmitterBlueprint | |
| resolution (defined in Obi.ObiEmitterBlueprintBase) | Obi.ObiEmitterBlueprintBase | |
| restDensity | Obi.ObiEmitterBlueprintBase | |
