Protected Member Functions | |
| override void | CreateTracker () |
| override Component | GetUnityCollider (ref bool enabled) |
| override void | FindSourceCollider () |
Protected Member Functions inherited from Obi.ObiColliderBase | |
| void | CreateRigidbody () |
| void | AddCollider () |
| void | RemoveCollider () |
Properties | |
| Collider | sourceCollider [get, set] |
| The Unity collider that this ObiCollider should mimic. More... | |
| ObiDistanceField | distanceField [get, set] |
| The distance field used by this collider. More... | |
Properties inherited from Obi.ObiColliderBase | |
| ObiCollisionMaterial | CollisionMaterial [get, set] |
| int | Filter [get, set] |
| float | Thickness [get, set] |
| bool | Inverted [get, set] |
| ObiShapeTracker | Tracker [get] |
| ObiColliderHandle | Handle [get] |
| ObiForceZone | ForceZone [get, set] |
| ObiRigidbodyBase | Rigidbody [get] |
Additional Inherited Members | |
Public Member Functions inherited from Obi.ObiColliderBase | |
| void | ForceUpdate () |
| void | UpdateIfNeeded () |
Protected Attributes inherited from Obi.ObiColliderBase | |
| ObiColliderHandle | shapeHandle |
| ObiRigidbodyBase | obiRigidbody |
| bool | wasUnityColliderEnabled = true |
| bool | needsUpdate = true |
| ObiShapeTracker | tracker |
Add this component to any Collider that you want to be considered by Obi.
protectedvirtual |
Creates an OniColliderTracker of the appropiate type.
Implements Obi.ObiColliderBase.
getset |
Setting a distance field will cause the collider to ignore its m_SourceCollider and use the distance field instead.
getset |
This is automatically set when you first create the ObiCollider component, but you can override it afterwards.
