Obi.ObiAerodynamicConstraintsBatch Member List
This is the complete list of members for Obi.ObiAerodynamicConstraintsBatch, including all inherited members.
ActivateAllConstraints() (defined in Obi.ObiConstraintsBatch)Obi.ObiConstraintsBatch
ActivateConstraint(int constraintIndex) (defined in Obi.ObiConstraintsBatch)Obi.ObiConstraintsBatch
activeConstraintCount (defined in Obi.ObiConstraintsBatch)Obi.ObiConstraintsBatch
AddConstraint(int index, float area, float drag, float lift) (defined in Obi.ObiAerodynamicConstraintsBatch)Obi.ObiAerodynamicConstraintsBatch
AddToSolver(ObiSolver solver) (defined in Obi.ObiAerodynamicConstraintsBatch)Obi.ObiAerodynamicConstraintsBatchvirtual
aerodynamicCoeffsObi.ObiAerodynamicConstraintsBatch
Clear() (defined in Obi.ObiAerodynamicConstraintsBatch)Obi.ObiAerodynamicConstraintsBatchvirtual
constraintCount (defined in Obi.ObiConstraintsBatch)Obi.ObiConstraintsBatch
constraintType (defined in Obi.ObiAerodynamicConstraintsBatch)Obi.ObiAerodynamicConstraintsBatch
CopyConstraint(ObiConstraintsBatch batch, int constraintIndex) (defined in Obi.ObiConstraintsBatch)Obi.ObiConstraintsBatchprotectedvirtual
DeactivateAllConstraints() (defined in Obi.ObiConstraintsBatch)Obi.ObiConstraintsBatch
DeactivateConstraint(int constraintIndex) (defined in Obi.ObiConstraintsBatch)Obi.ObiConstraintsBatch
GetConstraintIndex(int constraintId)Obi.ObiConstraintsBatch
GetParticlesInvolved(int index, List< int > particles) (defined in Obi.ObiAerodynamicConstraintsBatch)Obi.ObiAerodynamicConstraintsBatchvirtual
implementation (defined in Obi.ObiAerodynamicConstraintsBatch)Obi.ObiAerodynamicConstraintsBatch
initialActiveConstraintCount (defined in Obi.ObiConstraintsBatch)Obi.ObiConstraintsBatch
IsConstraintActive(int index) (defined in Obi.ObiConstraintsBatch)Obi.ObiConstraintsBatch
lambdasObi.ObiConstraintsBatch
m_ActiveConstraintCount (defined in Obi.ObiConstraintsBatch)Obi.ObiConstraintsBatchprotected
m_BatchImpl (defined in Obi.ObiAerodynamicConstraintsBatch)Obi.ObiAerodynamicConstraintsBatchprotected
m_ConstraintCount (defined in Obi.ObiConstraintsBatch)Obi.ObiConstraintsBatchprotected
m_IDs (defined in Obi.ObiConstraintsBatch)Obi.ObiConstraintsBatchprotected
m_IDToIndexObi.ObiConstraintsBatchprotected
m_InitialActiveConstraintCount (defined in Obi.ObiConstraintsBatch)Obi.ObiConstraintsBatchprotected
Merge(ObiActor actor, IObiConstraintsBatch other) (defined in Obi.ObiAerodynamicConstraintsBatch)Obi.ObiAerodynamicConstraintsBatchvirtual
ObiAerodynamicConstraintsBatch(ObiAerodynamicConstraintsData constraints=null) (defined in Obi.ObiAerodynamicConstraintsBatch)Obi.ObiAerodynamicConstraintsBatch
particleIndicesObi.ObiConstraintsBatch
ParticlesSwapped(int index, int newIndex) (defined in Obi.ObiConstraintsBatch)Obi.ObiConstraintsBatch
RegisterConstraint()Obi.ObiConstraintsBatchprotected
RemoveConstraint(int constraintIndex) (defined in Obi.ObiConstraintsBatch)Obi.ObiConstraintsBatch
RemoveFromSolver(ObiSolver solver) (defined in Obi.ObiAerodynamicConstraintsBatch)Obi.ObiAerodynamicConstraintsBatchvirtual
SwapConstraints(int sourceIndex, int destIndex) (defined in Obi.ObiAerodynamicConstraintsBatch)Obi.ObiAerodynamicConstraintsBatchprotectedvirtual
