Blend shapes
Three questions:
1. Do blend shapes affect Obi SoftBody simulation in any way? I.e. if a skinned mesh is changed through blend shapes, does that change transfer into the simulation as a new "rest state"?
2. Is it possible to run Obi SoftBody on a compute buffer of your own choosing? I.e., imagine you have your own skinning method and want to run Obi SoftBody on it after the skinning.
3. Can you initialize a mesh programmatically to run on Obi SoftBody?
Thanks for your time.
(01-02-2019, 05:14 PM)RandomWaterbird Wrote: Hi,
Three questions:
1.- No, blend shapes are not accounted for when performing the simulation, as part of what makes the simulation possible is a pretty costly precomputation step (that would have to be performed every frame for blend shapes).
2.- Obi uses Unity's standard SkinnedMeshRenderer for skinning. Any modifications you want to do after it (such as in the vertex shader) should be doable.
3.- Yes you can. However, the initialization method is a coroutine and will take a while to get completed. (since it performs the heavy precomputation I talked about in question #1).
