29-07-2024, 03:54 PM
I am working on a closed curve, to simulate and elastic behaviour. this lastic should be manipulated by a rigid object to be hooked on some obstacles and create figures with it. The problem is that after a bit of tention the follision fails, and I think the problem is given by the following
"Couldn't create a Convex Mesh from source mesh "extrudedMesh" within the maximum polygons limit (256). The partial hull will be used. Consider simplifying your mesh. UnityEngine.GUIUtility
rocessEvent (int,intptr,bool&)."
The error refers to the rope model. It seems really strange to me because: 1. the rope meash is not created by me but by obi, 2. i was working on a different Pc and there i didn't get errors of these type.
So i don't unterstand if the error is related to the machine performances or there is any setting that i didn't change
![Lengua Lengua](https://obi.virtualmethodstudio.com/forum/images/smilies/tongue.png)
