Obi Collider and Jump
Lengua
Hello. Thank you for a wonderful product Lengua . I have a question.
I'm using a sphere (RubberBall) as a character with Softbody Controller. On various game objects I put a Obi Collider script. The problem is that I can use "jump button" off all surfaces even vertical ones, can I somehow mark that this is not the ground? Confundido .
Best.
(29-01-2023, 10:36 AM)grinog4 Wrote: Hello. Thank you for a wonderful product Lengua . I have a question.
Best.
You do this the same way you would for any other game in Unity. There's many ways to determine whether a collider as "ground" or not, none of them specific to Obi (since Colliders are part of Unity, the ObiCollider component simply tells Obi to use a specific collider). Here's 3 different methods you can use:
- Put the collider in a specific layer, then in your code check whether the collider is part of that layer or not. This is probably the simplest method but also the most cumbersome to use.
- Send a raycast downwards from the position of your softbody, see if it hits any collider to determine whether there's something directly below it.
- Check the contact normal of the surface you're colliding against, and calculate its slope to determine whether it's horizontal ground or something else.
