Play 3D Softbody in 2D mode.
My main issue that playing 3d softbody in 2d mode but when i set 2d mode to obi solver,  3d mesh is broken like below images(a and b) and then i found this topic(http://obi.virtualmethodstudio.com/forum...-1488.html) and i am trying to add softbody to unity default 2d plane but I couldn't success like this video-> https://www.youtube.com/watch?v=jsT5JXExQ00
I shared my settings below so how can i make 2d softbody like that video->http://obi.virtualmethodstudio.com/forum...-1488.html
a->
b->
My current settings
Set your blueprint's max anisotropy to 1, re-generate the blueprint and re-bind the skin. That should work. Anisotropy changes the shape of particles to adapt to a local 3D volume, since you're working in 2D you don't want this to happen.
(09-01-2023, 10:25 AM)josemendez Wrote: Hi,
Thanks but that doesn't work unfortunately.
(09-01-2023, 01:39 PM)patriot4947 Wrote: Thanks but that doesn't work unfortunately.
Just tried it myself and seems to work fine. Used a simple tessellated plane, vertex mode for surface sampling (since I wanted exactly one particle per vertex) and max anisotropy set to 1:
Could you specify in what way it doesn't work for you? Isn't the simulation running, is there any kind of glitches or errors? If so, what kind?
(09-01-2023, 01:52 PM)josemendez Wrote: Hi,
Thank you for your quick response. I changed the default Unity plane with custom everything is worked fine.
