When changing the scale of a softbody skinner, I get the following error:
[Error] console:Mesh.SetBoneWeights() failed: Vertex [...] has zero weights.
The skinner appears fine in the editor, but when I press "Play", the skinner snaps back to it's original, unscaled size and the error appears (See attached GIF.)
My Obi Solver is set up as the RedDragon example, with the Softbody and Softbody skinner attached to different GameObjects.
BTW, if I set the skinner scale back to '1', re-bind and press "Play", the error message goes away.
Is this a bug or might I be doing something wrong?
Thanks,
David
Using Obi Softbody 6.4 with Unity 2020.3.30f1
BTW, here's the full stack trace:
Thanks,
David
ObiSoftbodySkinner.SetBoneWeights() at /Obi/Scripts/Softbody/Rendering/ObiSoftbodySkinner.cs:386
384: {
385: if (m_BoneWeights != null && m_BoneWeights.count > 0)
-->386: m_SoftMesh.SetBoneWeights(m_BonesPerVertex.AsNativeArray<byte>(), m_BoneWeights.AsNativeArray<BoneWeight1>());
387: }
ObiSoftbodySkinner.Setup() at /Obi/Scripts/Softbody/Rendering/ObiSoftbodySkinner.cs:135
133: m_SoftMesh = Instantiate(m_Target.sharedMesh);
-->135: SetBoneWeights();
136: AppendBindposes();
137: AppendSoftBones();
ObiSoftbodySkinner.UpdateSoftBones() at /Obi/Scripts/Softbody/Rendering/ObiSoftbodySkinner.cs:218
216: }
217: else
-->218: Setup();
219: }
ObiActor.Interpolate() at /Obi/Scripts/Common/Actors/ObiActor.cs:1223
1222: if (OnInterpolate != null)
-->1223: OnInterpolate(this);
1224: }
ObiSoftbody.Interpolate() at /Obi/Scripts/Softbody/Actors/ObiSoftbody.cs:288
286: SetSelfCollisions(selfCollisions);
-->288: base.Interpolate();
289: }
ObiSolver.Interpolate() at /Obi/Scripts/Common/Solver/ObiSolver.cs:1641
1640: foreach (ObiActor actor in actors)
-->1641: actor.Interpolate();
1643: }
ObiUpdater.Interpolate() at /Obi/Scripts/Common/Updaters/ObiUpdater.cs:132
130: foreach (ObiSolver solver in solvers)
131: if (solver != null)
-->132: solver.Interpolate(stepDeltaTime, accumulatedTime);
133: }
134: }
ObiFixedUpdater.Update() at /Obi/Scripts/Common/Updaters/ObiFixedUpdater.cs:64
62: {
63: ObiProfiler.EnableProfiler();
-->64: Interpolate(Time.fixedDeltaTime, accumulatedTime);
65: ObiProfiler.DisableProfiler();
