Different shapes for obi fluid?
Obi fluid currently emits balls. Would it be possible to make it emit long pill shapes?
We're trying to get the following result by using your addon (Warning +18 video):
https://photos.app.goo.gl/95cNMwLK7rwCn3d48
Could you kindly share with us if this is possible? If yes, would you be able to share the parameters?
Thanks in advance!
By default, Obi emits anisotropic particles --> ellipsoids that approximate the local surface shape. Just make sure your max anisotropy setting (found in the solver) is set > 1. See:
Other than ellipsoids, it is not possible to emit any other shape since Obi is inherently particle-based.
