Adding Emission to particles
Hey there everyone. I wanted to add a glowing effect to my liquid, but finding code to add emission via meta pass to random shaders didnt seem to be working. I dont need any blur lighting effect outside, and I dont need any lighting of nearby surfaces.
I'm hoping you can give me some help as inserting a few similar versions of an emission pass into the ParticleShader.shader has not seemed to work.
Thank you
(05-02-2021, 03:38 AM)Azimuth Wrote: Hey there everyone. I wanted to add a glowing effect to my liquid, but finding code to add emission via meta pass to random shaders didnt seem to be working. I dont need any blur lighting effect outside, and I dont need any lighting of nearby surfaces.
Thank you
Emission with no blur lighting (bloom) and no lightning on nearby surfaces just reduces to a constant additive term in the lighting equation. You can modify the fluid shader slightly, by adding this line at the end of FluidShader.shader right before the final return:
fo.color.rgb += half3(0.5f,0,0); // insert here your emission color.
Of course you can get fancy by using a material property instead of a hard-coded variable.
cheers!
