Standard (Backfaces) Shader not shading front faces
I'm working on some clothing that looked weird because back faces weren't rendering, so I used the Standard (Backfaces) shader. As soon as I did, the front faces stopped drawing:
https://imgur.com/a/KJwAD
I'm running the latest stable version of Unity 2017, on Windows 10, using DirectX11, and the skirt model has no thickness.
(12-12-2017, 12:40 AM)aaronfjerstad Wrote: I'm working on some clothing that looked weird because back faces weren't rendering, so I used the Standard (Backfaces) shader. As soon as I did, the front faces stopped drawing:
This is the expected behaviour. The Standard (Backfaces) shader renders backfaces only. To show both front and back faces, you need to apply both materials -Standard and Standard(backfaces) like it is done in all sample scenes-. This has the added benefit that it allows you to have different textures/material properties for front and back faces.
cheers!
