How to use your purchase / order ID to receive full support
Información
If you want full support for your project we have to make sure you own the asset you are asking about.
We need to check the order number (OR) / invoice number the Asset Store gives you after purchasing our assets.
We recommend you fill the information in your profile as soon as possible
What's the protocol:
- You ask something that requires a big amount of time from our side or requires specific support.
- We will check if your profile info contains the ownership flag of that asset.
- If not, we will visit your profile information and check if the invoice number is valid, and add the asset ownership flag to your profile
- If you don't have the order number in your profile, we reserve the right to ask for it.
To add the numbers:
- Go to User CP or Control Panel (top left corner, under "Welcome Back..." black bar).
http://obi.virtualmethodstudio.com/forum/usercp.php
- Go to "Edit Profile" on the list
- Add your numbers on the form's "additional info" section.
Thank you for your time!
