Can anyone explain what the Minimum pool size?
In Inspector panel
edit : Also Phase in inspector in Obj Emitter
In Inspector panel
Help What is minimum pool size?
In Inspector panel edit : Also Phase in inspector in Obj Emitter
03-08-2020, 08:28 AM
(This post was last modified: 03-08-2020, 08:29 AM by josemendez.)
(02-08-2020, 01:41 PM)0xhex Wrote: Can anyone explain what the Minimum pool size? Hi, "Minimum pool size" is the minimum percentage of particles that must be inactive(in the emitter's particle pool) for the emitter to continue emitting particles. This is used to prevent the emitter from resuming emission as soon as a single particle is available. Phases are used to control collisions between particles and colliders. See: http://obi.virtualmethodstudio.com/tutor...sions.html |
« Next Oldest | Next Newest »
