Help What is minimum pool size? - Printable Version +- Obi Official Forum (https://obi.virtualmethodstudio.com/forum) +-- Forum: Obi Users Category (https://obi.virtualmethodstudio.com/forum/forum-1.html) +--- Forum: Obi Fluid (https://obi.virtualmethodstudio.com/forum/forum-3.html) +--- Thread: Help What is minimum pool size? (/thread-2398.html) |
What is minimum pool size? - 0xhex - 02-08-2020 Can anyone explain what the Minimum pool size? In Inspector panel edit : Also Phase in inspector in Obj Emitter RE: What is minimum pool size? - josemendez - 03-08-2020 (02-08-2020, 01:41 PM)0xhex Wrote: Can anyone explain what the Minimum pool size? Hi, "Minimum pool size" is the minimum percentage of particles that must be inactive(in the emitter's particle pool) for the emitter to continue emitting particles. This is used to prevent the emitter from resuming emission as soon as a single particle is available. Phases are used to control collisions between particles and colliders. See: http://obi.virtualmethodstudio.com/tutorials/collisions.html |
