Hello! I'm trying to use Obi Softbody's system on some of my custom models.
I've followed the setup steps in the documentation, as well as a video I found on YouTube.
I'm not 100% sure what I'm doing wrong, I think I'm not setting the blueprints correctly..
What I'm doing is this:
I import the model, set make it readable and writeable.
Then I create a new blueprint, attach the model to the input mesh and click the generate.
After that, I create the softbody object via the editor menu button.
I attach the mesh to the SkinnedMeshRenderer and drop a material.
Then I attach the blueprint, and physics material.
Finally I click on the "bind skin" button.
This is what it looks like in real time:
With particles rendering: https://i.imgur.com/XBkOppN.mp4
Without particles rendering: https://i.imgur.com/lzQ0W3w.mp4
This is the error I'm getting when running the Unity scene:
I'd appreciate your help with this.
Quote:Mesh.SetBoneWeights() failed: Vertex 521 has zero weights.
UnityEngine.Mesh:SetBoneWeights (Unity.Collections.NativeArray`1<byte>,Unity.Collections.NativeArray`1<UnityEngine.BoneWeight1>)
Obi.ObiSoftbodySkinner:SetBoneWeights () (at Assets/! Imported/Obi/Scripts/Softbody/Rendering/ObiSoftbodySkinner.cs:386)
Obi.ObiSoftbodySkinner:Setup () (at Assets/! Imported/Obi/Scripts/Softbody/Rendering/ObiSoftbodySkinner.cs:135)
Obi.ObiSoftbodySkinner:UpdateSoftBones (Obi.ObiActor) (at Assets/! Imported/Obi/Scripts/Softbody/Rendering/ObiSoftbodySkinner.cs:218)
Obi.ObiActor:Interpolate () (at Assets/! Imported/Obi/Scripts/Common/Actors/ObiActor.cs:1222)
Obi.ObiSoftbody:Interpolate () (at Assets/! Imported/Obi/Scripts/Softbody/Actors/ObiSoftbody.cs:288)
Obi.ObiSolver:Interpolate (single,single) (at Assets/! Imported/Obi/Scripts/Common/Solver/ObiSolver.cs:1641)
Obi.ObiUpdater:Interpolate (single,single) (at Assets/! Imported/Obi/Scripts/Common/Updaters/ObiUpdater.cs:122)
Obi.ObiFixedUpdater:Update () (at Assets/! Imported/Obi/Scripts/Common/Updaters/ObiFixedUpdater.cs:64)
