04-10-2021, 07:44 AM
(This post was last modified: 04-10-2021, 07:44 AM by josemendez.)
(03-10-2021, 02:50 PM)Notreturn Wrote: Hello Again.
I hope this is gonna be the last one ^^
I have progressed so much with your help.
But when i try to use 2 objects with one solver unity crashes.
I mean. When one solver andĀ 2 objects children of this solver and if these 2 objects are active at the same time and onceĀ press Play button unity crashes.
I havent changed anything in the solver values. Just the Substeps is 5.
I'm unable to reproduce this, also never had similar reports from other users. Most sample scenes have multiple objects in the solver and they run fine.
Are you using custom meshes in these objects, and if so, are you sure they're 2-manifold? Non-manifold meshes are not supported by Obi and they can cause crashes at runtime if they pass the blueprint generating stage undetected, see:
