Convert from unity 2021 to 2022 - Printable Version +- Obi Official Forum (https://obi.virtualmethodstudio.com/forum) +-- Forum: Obi Users Category (https://obi.virtualmethodstudio.com/forum/forum-1.html) +--- Forum: Obi Rope (https://obi.virtualmethodstudio.com/forum/forum-4.html) +--- Thread: Convert from unity 2021 to 2022 (/thread-3814.html) Pages:
1
2
RE: Convert from unity 2021 to 2022 - lacasrac - 04-04-2023 (29-03-2023, 01:38 PM)lacasrac Wrote: obi 6.5.1 line 11 public static class ConstraintSorter { (29-03-2023, 01:58 PM)josemendez Wrote: That's strange, could you check whether the file located at Obi/Assets/Obi/Scripts/Common/Backends/Burst/DataStructures/ConstraintBatcher/ConstraintSorter.cs defines ConstraintSorter as: line 11 public static class ConstraintSorter { RE: Convert from unity 2021 to 2022 - josemendez - 04-04-2023 (04-04-2023, 09:53 AM)lacasrac Wrote: line 11 That's not Obi 6.5.1, it's either 6.3 or 6.4. You can check the version in the Obi/CHANGELOG_rope.txt file. The current version you have installed is the one at the top of the file. The first few lines should look something like this: Quote:## [6.5.1] The change in bold font is the one that you're interested in. There was also a pretty large memory leak fixed so you definitely want to at least be using 6.5. If the changelog file does look like that, maybe you've installed an older version of another Obi asset on top of ObiRope 6.5.1? That will replace common files with the ones in the version you're installing, hence why it's recommended to install the same version for all assets. kind regards, |
