Convert from unity 2021 to 2022
unity 2021:
public void SetSimplices(int[] simplices, SimplexCounts counts)
    this.simplices.CopyFrom(simplices);
how to convert this line to 2022?
Assets\Obi\Scripts\Common\Backends\Burst\Solver\BurstSolverImpl.cs(314,37): error CS1503: Argument 1: cannot convert from 'int[]' to 'in Unity.Collections.NativeArray<int>'
(19-03-2023, 05:06 PM)lacasrac Wrote: unity 2021:
You can use CopyFromNBC from the Unity.Collections.NotBurstCompatible namespace, since CopyFrom has been removed in the latest Collections package version:
https://docs.unity3d.com/Packages/com.un...sions.html
(19-03-2023, 06:17 PM)josemendez Wrote: Hi!
one more thing:
private void UpdateKinematicVelocities(float stepTime)
//TODO this freezes unity FPS, so I commented out, lot of WARNINGS
    // differentiate positions/orientations to get our own velocites for kinematic objects.
    // when calling Physics.Simulate, MovePosition/Rotation do not work correctly. Also useful for animations.
    if (unityRigidbody.isKinematic)
        // differentiate positions to obtain linear velocity:
        unityRigidbody.velocity = (transform.position - prevPosition) / stepTime;
        // differentiate rotations to obtain angular velocity:
        var delta = transform.rotation * Quaternion.Inverse(prevRotation);
        unityRigidbody.angularVelocity = new Vector3(delta.x, delta.y, delta.z) * 2.0f / stepTime;
    prevPosition = transform.position;
    prevRotation = transform.rotation;
unity 2022 throw a lot of warnings (like you can't update the velocity on a kinematic body), and FPS goes to 15-30 FPS in the editor from 80-90
so I had to comment that out. Is it okay? Or I need this one?
Seems like Unity 2022 does no longer support setting the velocity of a kinematic rigidbody and will throw a warning when doing so.
Commenting this piece of code will disable CCD for kinematic rigidbodies, which depending on what you're doing might be a bummer. Will work around this and get you an alternative asap.
(21-03-2023, 09:07 AM)josemendez Wrote: Seems like Unity 2022 does no longer support setting the velocity of a kinematic rigidbody and will throw a warning when doing so.
ok thanks, any news?
(29-03-2023, 07:12 AM)lacasrac Wrote: ok thanks, any news?
Sorry, I forgot about this. Triste Please accept my apologies!!
You can find the modified scripts attached. Replace the scripts at:
Assets/Obi/Scripts/Common/Collisions/ObiRigidbody.cs
and
Assets/Obi/Scripts/Common/DataStructures/ColliderRigidbody.cs
with the ones attached, that should get rid of the warning. The workaround is basically to store our own linear/angular velocities for kinematic rigidbodies, instead of relying on Unity for this.
Should you encounter any issue with these modified scripts, please let me know.
.cs   ColliderRigidbody.cs (Size: 3.18 KB / Downloads: 1)
.cs   ObiRigidbody.cs (Size: 2.97 KB / Downloads: 1)
(29-03-2023, 09:59 AM)josemendez Wrote: Sorry, I forgot about this. Triste Please accept my apologies!!
and
thanks this is working,
Compilation was requested for method `Unity.Jobs.IJobExtensions+JobStruct`1[[Obi.ConstraintSorter+CountSortPerFirstParticleJob`1[[Obi.BurstContact, Obi, Version=0.0.0.0, Culture=neutral, PublicKeyToken=null]], Obi, Version=0.0.0.0, Culture=neutral, PublicKeyToken=null]], UnityEngine.CoreModule, Version=0.0.0.0, Culture=neutral, PublicKeyToken=null::Execute(Obi.ConstraintSorter+CountSortPerFirstParticleJob`1[[Obi.BurstContact, Obi, Version=0.0.0.0, Culture=neutral, PublicKeyToken=null]]&, Obi, Version=0.0.0.0, Culture=neutral, PublicKeyToken=null|System.IntPtr, mscorlib, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089|System.IntPtr, mscorlib, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089|Unity.Jobs.LowLevel.Unsafe.JobRanges&, UnityEngine.CoreModule, Version=0.0.0.0, Culture=neutral, PublicKeyToken=null|System.Int32, mscorlib, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089)` but it is not a known Burst entry point. This may be because the [BurstCompile] method is defined in a generic class, and the generic class is not instantiated with concrete types anywhere in your code.
Compilation was requested for method `Unity.Jobs.IJobParallelForExtensions+ParallelForJobStruct`1[[Obi.ConstraintSorter+SortSubArraysJob`1[[Obi.BurstContact, Obi, Version=0.0.0.0, Culture=neutral, PublicKeyToken=null]], Obi, Version=0.0.0.0, Culture=neutral, PublicKeyToken=null]], UnityEngine.CoreModule, Version=0.0.0.0, Culture=neutral, PublicKeyToken=null::Execute(Obi.ConstraintSorter+SortSubArraysJob`1[[Obi.BurstContact, Obi, Version=0.0.0.0, Culture=neutral, PublicKeyToken=null]]&, Obi, Version=0.0.0.0, Culture=neutral, PublicKeyToken=null|System.IntPtr, mscorlib, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089|System.IntPtr, mscorlib, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089|Unity.Jobs.LowLevel.Unsafe.JobRanges&, UnityEngine.CoreModule, Version=0.0.0.0, Culture=neutral, PublicKeyToken=null|System.Int32, mscorlib, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089)` but it is not a known Burst entry point. This may be because the [BurstCompile] method is defined in a generic class, and the generic class is not instantiated with concrete types anywhere in your code.
Compilation was requested for method `Unity.Jobs.IJobExtensions+JobStruct`1[[Obi.ConstraintBatcher+BatchContactsJob`1[[Obi.ContactProvider, Obi, Version=0.0.0.0, Culture=neutral, PublicKeyToken=null]], Obi, Version=0.0.0.0, Culture=neutral, PublicKeyToken=null]], UnityEngine.CoreModule, Version=0.0.0.0, Culture=neutral, PublicKeyToken=null::Execute(Obi.ConstraintBatcher+BatchContactsJob`1[[Obi.ContactProvider, Obi, Version=0.0.0.0, Culture=neutral, PublicKeyToken=null]]&, Obi, Version=0.0.0.0, Culture=neutral, PublicKeyToken=null|System.IntPtr, mscorlib, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089|System.IntPtr, mscorlib, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089|Unity.Jobs.LowLevel.Unsafe.JobRanges&, UnityEngine.CoreModule, Version=0.0.0.0, Culture=neutral, PublicKeyToken=null|System.Int32, mscorlib, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089)` but it is not a known Burst entry point. This may be because the [BurstCompile] method is defined in a generic class, and the generic class is not instantiated with concrete types anywhere in your code.
Compilation was requested for method `Unity.Jobs.IJobExtensions+JobStruct`1[[Obi.ConstraintBatcher+BatchContactsJob`1[[Obi.FluidInteractionProvider, Obi, Version=0.0.0.0, Culture=neutral, PublicKeyToken=null]], Obi, Version=0.0.0.0, Culture=neutral, PublicKeyToken=null]], UnityEngine.CoreModule, Version=0.0.0.0, Culture=neutral, PublicKeyToken=null::Execute(Obi.ConstraintBatcher+BatchContactsJob`1[[Obi.FluidInteractionProvider, Obi, Version=0.0.0.0, Culture=neutral, PublicKeyToken=null]]&, Obi, Version=0.0.0.0, Culture=neutral, PublicKeyToken=null|System.IntPtr, mscorlib, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089|System.IntPtr, mscorlib, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089|Unity.Jobs.LowLevel.Unsafe.JobRanges&, UnityEngine.CoreModule, Version=0.0.0.0, Culture=neutral, PublicKeyToken=null|System.Int32, mscorlib, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089)` but it is not a known Burst entry point. This may be because the [BurstCompile] method is defined in a generic class, and the generic class is not instantiated with concrete types anywhere in your code.
and this warnings? Sonrisa
(29-03-2023, 12:49 PM)lacasrac Wrote: thanks this is working,
Newer Burst versions broke generic job compilation (in line with Unity's policy of breaking 3 features for every new one they add). This was addressed in Obi 6.5.1, in case you're using an older version I'd suggest updating to 6.5.1 since the fix/patch is not trivial to apply.
In case you're already using 6.5.1, may I ask which version of the Burst package you're currently using?
(29-03-2023, 01:20 PM)josemendez Wrote: Hi!
obi 6.5.1
burst 1.8.3
I try soon with 1.8.4
(29-03-2023, 01:38 PM)lacasrac Wrote: obi 6.5.1
That's strange, could you check whether the file located at Obi/Assets/Obi/Scripts/Common/Backends/Burst/DataStructures/ConstraintBatcher/ConstraintSorter.cs defines ConstraintSorter as:
public class ConstraintSorter<T> where T : struct, IConstraint
(roughly line 12 in the file).
(29-03-2023, 01:38 PM)lacasrac Wrote: burst 1.8.3
Latest Burst version that didn't exhibit this issue was 1.6. I'm not sure what the status is for 1.8.4.
