Help how to make particles not following emmiter? - Printable Version +- Obi Official Forum (https://obi.virtualmethodstudio.com/forum) +-- Forum: Obi Users Category (https://obi.virtualmethodstudio.com/forum/forum-1.html) +--- Forum: Obi Fluid (https://obi.virtualmethodstudio.com/forum/forum-3.html) +--- Thread: Help how to make particles not following emmiter? (/thread-3632.html) |
how to make particles not following emmiter? - AAABBBCCC - 03-11-2022 hi i made a firetruck and i used obi fluid to create water, but when truck moves or rotate particles follow its movements . what should i do to make particles not following emmiter? RE: how to make particles not following emmiter? - josemendez - 03-11-2022 (03-11-2022, 07:34 AM)AAABBBCCC Wrote: hi Particles won't follow the emitter, they'll follow the solver. This is because the simulation takes place in the solver's local space, see: http://obi.virtualmethodstudio.com/manual/6.3/obisolver.html Quote:Solvers always perform the simulation in local space. This means that translating, rotating or scaling the solver will rigidly transform the simulation as a whole. The typical setup to simulate in world space instead is to have a single solver at the center of your scene, and then have multiple emitters under its hierarchy. kind regards, RE: how to make particles not following emmiter? - AAABBBCCC - 03-11-2022 (03-11-2022, 08:34 AM)josemendez Wrote: Particles won't follow the emitter, they'll follow the solver. This is because the simulation takes place in the solver's local space, see:Thank you for the super fast response |
