Help Tether Constraint is not an available option - Printable Version +- Obi Official Forum (https://obi.virtualmethodstudio.com/forum) +-- Forum: Obi Users Category (https://obi.virtualmethodstudio.com/forum/forum-1.html) +--- Forum: Obi Rope (https://obi.virtualmethodstudio.com/forum/forum-4.html) +--- Thread: Help Tether Constraint is not an available option (/thread-2991.html) |
Tether Constraint is not an available option - wilderness26 - 25-06-2021 Hi, I'd like to set up a tether constraint, but it doesn't appear to be an option if I try to Add Component to an object and search for "tether" RE: Tether Constraint is not an available option - josemendez - 28-06-2021 (25-06-2021, 10:23 PM)wilderness26 Wrote: Hi, I'd like to set up a tether constraint, but it doesn't appear to be an option if I try to Add Component to an object and search for "tether" Hi there, Constraints are not independent components. They're part of each specific actor component, and their controls are exposed in the actor's inspector. Each specific actor makes use of certain types of constraints. Tethers are only used to reduce stretching in cloth, they're not available for ropes. My guess is that you are looking for attachments instead? See: http://obi.virtualmethodstudio.com/manual/6.2/attachments.html |
