Help Creating obi rope prefab - Printable Version +- Obi Official Forum (https://obi.virtualmethodstudio.com/forum) +-- Forum: Obi Users Category (https://obi.virtualmethodstudio.com/forum/forum-1.html) +--- Forum: Obi Rope (https://obi.virtualmethodstudio.com/forum/forum-4.html) +--- Thread: Help Creating obi rope prefab (/thread-2607.html) Pages:
1
2
RE: Creating obi rope prefab - josemendez - 11-12-2020 (10-12-2020, 06:47 PM)amismail Wrote: I am Uploading the sample project to dropbox and will share the link with you as soon as it finishes Hi, The mesh you're using for the rope renderer is not readable. This is evidenced by the error message being spammed to the console: Unity will prevent non-readable meshes from being modified at runtime. The solution is to simply enable the "read/write enabled" checkbox in your mesh import settings as the error message tells you to do. I've marked it with a red arrow in the above screenshot. After this, the prefab will work just fine. For more info, see: https://docs.unity3d.com/2019.3/Documentation/Manual/FBXImporter-Model.html cheers! RE: Creating obi rope prefab - amismail - 14-12-2020 (11-12-2020, 10:04 AM)josemendez Wrote: Hi, Thanks a lot this solved the issue, thanks again for the help |
