Help  Retrieving contacts count only from a specific collision
Pregunta
Hey there! Hope you are all doing well!
I am using Obi fluid. I know that we could receive a contacts count with
e.contacts.Count
But it gives all current collision points. My question is there any chance to receive contacts count only for a specific collider? For example, the full count is 1000 and for a collider_1 the count is 300, for a collider_2 the count is 450, etc.
I am interested only in OnCollision event(simplex-collider).
Thank you!
You can count how many contacts reference a specific collider yourself. Simply check the collider referenced by each contact and if it's the one you're interested in, increase a counter. This is what is done in the FluidMaze sample scene to determine if the fluid is in contact with specific dye blocks.
See "Retrieving the collider involved in a contact" in the manual's scripting section:
You can also take a look at the sample script you'll find at the very end of that page. It checks if fluid is in contact with a specific trigger collider (by comparing its tag), and if so, accelerate particles in a direction opposite to gravity (effectively creating a zero-G zone).
Thank you for the quick response! Yep, it seems like I just missed this part!
