Help Retrieving contacts count only from a specific collision - Printable Version +- Obi Official Forum (https://obi.virtualmethodstudio.com/forum) +-- Forum: Obi Users Category (https://obi.virtualmethodstudio.com/forum/forum-1.html) +--- Forum: General (https://obi.virtualmethodstudio.com/forum/forum-5.html) +--- Thread: Help Retrieving contacts count only from a specific collision (/thread-3020.html) |
Retrieving contacts count only from a specific collision - Rearden - 13-07-2021 Hey there! Hope you are all doing well! I am using Obi fluid. I know that we could receive a contacts count with Code: e.contacts.Count I am interested only in OnCollision event(simplex-collider). Thank you! RE: Retrieving contacts count only from a specific collision - josemendez - 14-07-2021 You can count how many contacts reference a specific collider yourself. Simply check the collider referenced by each contact and if it's the one you're interested in, increase a counter. This is what is done in the FluidMaze sample scene to determine if the fluid is in contact with specific dye blocks. See "Retrieving the collider involved in a contact" in the manual's scripting section: http://obi.virtualmethodstudio.com/manual/6.2/scriptingcollisions.html You can also take a look at the sample script you'll find at the very end of that page. It checks if fluid is in contact with a specific trigger collider (by comparing its tag), and if so, accelerate particles in a direction opposite to gravity (effectively creating a zero-G zone). RE: Retrieving contacts count only from a specific collision - Rearden - 14-07-2021 Thank you for the quick response! Yep, it seems like I just missed this part! |
