Hello, I try to make wires with connectors on both ends for VR. The user will be able to take connectors in his hands. At first, I wanted to implement using startPrefab and endPrefab, but they are impossible to interact with and move. Then I tried to implement a longer wire using "pin constraint" based on the example in the "Rocker" scene. But during кщзу initialization, there is a space between "obi rope" and GameObjects.
I tried to fix this problem by changing the "pin constraint" position, but it did not help. Is there any way to fix this problem?
![[Image: image.png]](https://i.ibb.co/rdvsYtm/image.png)
![[Image: image.png]](https://i.ibb.co/j8FbGby/image.png)
![[Image: image.png]](https://i.ibb.co/qkFdjkG/image.png)
![[Image: image.png]](https://i.ibb.co/DGMB5zw/image.png)
Thank You
Sam Violin.
Thank You
Sam Violin.
