Help  Are Obi products going to be updated soon?
Lengua
1. I'm wondering if the Obi products will be updated (with bug fixes) on the Unity Asset store soon. Several bug fixes are floating around on the forums that I constantly have to hunt down and add when creating new projects using Obi Assets.
2. Would you create a video on how to control a softbody ball with a rigidbody - that actually collides with the floor.
I think I'm doing something wrong or missing a step. Every time I attempt it, the ball simply falls thru the floor.
Thanks
(07-03-2019, 05:16 AM)StudioTatsu Wrote: Hi,
Thanks
1. Yes, an update will be available very soon. We are trying to cram as many bug fixes as possible into it.
2. Why'd you want to do that? soft bodies already collide with other colliders, you can add forces and torques to them, so pretty much anything you can do with a rigid body you can also do with a softbody.
(07-03-2019, 07:48 AM)josemendez Wrote: 1. Yes, an update will be available very soon. We are trying to cram as many bug fixes as possible into it.
I was doing tests with unity standard wheel collider which requires at least one rigidbody to work.
(07-03-2019, 08:32 AM)StudioTatsu Wrote: I was doing tests with unity standard wheel collider which requires at least one rigidbody to work.
Wheel colliders and softbodies don't mix well becase they both model the same underlying system, but in very different ways. It's like using a projector on a screen to watch a movie, so to speak. Either use the projector or the screen, not both.
Softbodies are way too detailed for some aspects of tire deformation, and not detailed enough for many other important things.
Friction for instance, needs to be much more accurate than what softbodies can offer. Usually you want a curve-based friction model for wheels, while regular contacts (both in Obi and general purpose rigidbodies in most physics engines) use a much simpler linear piecewise cone approach that won't result in an engaging driving model.
Softbodies simulate a lot of phenomena that can just be omitted for tires, as they only add overhead and no discernible advantage: plasticity, work hardening, non-homogeneous density, etc.
Wheel colliders already account for tire deformation in their physics model, although they give no visual feedback of such deformation. There's many assets in the store meant to replace/extend wheel colliders and allow them to deform the wheel. Usually a simple vertex shader that procedurally squashes the mesh based on the wheel collider's feedback is cheap, convincing, and allows to decouple the physics model form the visual representation.
Edit: If you wanted, you could get both to work together (though I strongly advise against it). Wheel colliders do not need a rigidbody in the same GameObject, but they do need one up their hierarchy (the car rigidbody). Also, wheel colliders do not rotate by themselves as you probably already know. You have to set up a separate, rotating object to represent the wheel visually. So simply set up the wheel collider as usual, then create a softbody with some particles pinned where the tire meets the wheel rim and rotate it as you would with any other object. Note that the softbodies will not apply forces to the car, they will only deform in response to the floor. The wheel colliders still have the responsibility to prevent the car from falling trough the floor by applying forces to the rigidbody.
(07-03-2019, 08:58 AM)josemendez Wrote: Wheel colliders and softbodies don't mix well becase they both model the same underlying system, but in very different ways. It's like using a projector on a screen to watch a movie, so to speak. Either use the projector or the screen, not both.
I apologize. I probably should have worded that differently. I'm using wheel colliders to control the car.
The car body parts (Frame, Doors, windows) are softbody objects - not the wheels.
Wheelcolliders only work with a rigidbody in the hierarchy of the vehicle. The problem, I'm having is, when the wheels start driving, it leaves the softbody objects.
The wheel colliders are only used for raycasting, I need the softbody objects to follow the root transform and deform when they run into something.
The rigidbody is used to add force from the wheels to move the root transform.
I tried to pin the softbody particles to the root transform, but they either fell thru the floor OR didn't deform at all.
The question is, How do you make a softbody object move with or follow the root transform and still deform with collisions?
I tried following the docs and failed, if you can make a video, that would be great.
I got it working. I missed one checkbox.
