Hola , tengo problemas al intentar editar las particulas , no me sale el editor ni las particulas y me da esto en la consola:
Obi.ObiParticleActorEditor.DrawParticles () (at Assets/Obi/Editor/ObiParticleActorEditor.cs:332)
Obi.ObiClothEditor.DrawActorInfo () (at Assets/Obi/Editor/ObiClothEditor.cs:138)
Obi.ObiParticleActorEditor.OnSceneGUI () (at Assets/Obi/Editor/ObiParticleActorEditor.cs:262)
System.Reflection.MonoMethod.Invoke (System.Object obj, System.Reflection.BindingFlags invokeAttr, System.Reflection.Binder binder, System.Object[] parameters, System.Globalization.CultureInfo culture) (at <ac823e2bb42b41bda67924a45a0173c3>:0)
Rethrow as TargetInvocationException: Exception has been thrown by the target of an invocation.
System.Reflection.MethodBase.Invoke (System.Object obj, System.Object[] parameters) (at <ac823e2bb42b41bda67924a45a0173c3>:0)
UnityEditor.SceneView.CallOnSceneGUI () (at C:/buildslave/unity/build/Editor/Mono/SceneView/SceneView.cs:2833)
UnityEditor.SceneView.HandleSelectionAndOnSceneGUI () (at C:/buildslave/unity/build/Editor/Mono/SceneView/SceneView.cs:2122)
UnityEditor.SceneView.OnGUI () (at C:/buildslave/unity/build/Editor/Mono/SceneView/SceneView.cs:1983)
UnityEditor.HostView.Invoke (System.String methodName, System.Object obj) (at C:/buildslave/unity/build/Editor/Mono/HostView.cs:342)
UnityEditor.HostView.Invoke (System.String methodName) (at C:/buildslave/unity/build/Editor/Mono/HostView.cs:336)
UnityEditor.HostView.InvokeOnGUI (UnityEngine.Rect onGUIPosition, UnityEngine.Rect viewRect) (at C:/buildslave/unity/build/Editor/Mono/HostView.cs:310)
UnityEditor.DockArea.DrawView (UnityEngine.Rect viewRect, UnityEngine.Rect dockAreaRect, System.Boolean customBorder, System.Boolean floatingWindow, System.Boolean isBottomTab) (at C:/buildslave/unity/build/Editor/Mono/GUI/DockArea.cs:361)
UnityEditor.DockArea.OldOnGUI () (at C:/buildslave/unity/build/Editor/Mono/GUI/DockArea.cs:320)
UnityEngine.Experimental.UIElements.IMGUIContainer.DoOnGUI (UnityEngine.Event evt, UnityEngine.Matrix4x4 worldTransform, UnityEngine.Rect clippingRect, System.Boolean isComputingLayout) (at C:/buildslave/unity/build/Modules/UIElements/IMGUIContainer.cs:266)
UnityEngine.Experimental.UIElements.IMGUIContainer.HandleIMGUIEvent (UnityEngine.Event e, UnityEngine.Matrix4x4 worldTransform, UnityEngine.Rect clippingRect) (at C:/buildslave/unity/build/Modules/UIElements/IMGUIContainer.cs:438)
UnityEngine.Experimental.UIElements.IMGUIContainer.HandleIMGUIEvent () (at C:/buildslave/unity/build/Modules/UIElements/IMGUIContainer.cs:412)
UnityEngine.Experimental.UIElements.ImmediateStylePainter.DrawImmediate (System.Action callback) (at C:/buildslave/unity/build/Modules/UIElements/ImmediateStylePainter.cs:113)
UnityEngine.Experimental.UIElements.IMGUIContainer.DoRepaint (UnityEngine.Experimental.UIElements.IStylePainter painter) (at C:/buildslave/unity/build/Modules/UIElements/IMGUIContainer.cs:98)
UnityEngine.Experimental.UIElements.VisualElement.Repaint (UnityEngine.Experimental.UIElements.IStylePainter painter) (at C:/buildslave/unity/build/Modules/UIElements/VisualElement.cs:845)
UnityEngine.Experimental.UIElements.VisualTreeRepaintUpdater.PaintSubTree (UnityEngine.Experimental.UIElements.VisualElement root, UnityEngine.Matrix4x4 offset, System.Boolean shouldClip, System.Boolean shouldCache, UnityEngine.Rect currentGlobalClip) (at C:/buildslave/unity/build/Modules/UIElements/VisualTreeRepaintUpdater.cs:310)
UnityEngine.Experimental.UIElements.VisualTreeRepaintUpdater.PaintSubTreeChildren (UnityEngine.Experimental.UIElements.VisualElement root, UnityEngine.Matrix4x4 offset, System.Boolean shouldClip, System.Boolean shouldCache, UnityEngine.Rect textureClip) (at C:/buildslave/unity/build/Modules/UIElements/VisualTreeRepaintUpdater.cs:328)
UnityEngine.Experimental.UIElements.VisualTreeRepaintUpdater.PaintSubTree (UnityEngine.Experimental.UIElements.VisualElement root, UnityEngine.Matrix4x4 offset, System.Boolean shouldClip, System.Boolean shouldCache, UnityEngine.Rect currentGlobalClip) (at C:/buildslave/unity/build/Modules/UIElements/VisualTreeRepaintUpdater.cs:314)
UnityEngine.Experimental.UIElements.VisualTreeRepaintUpdater.Update () (at C:/buildslave/unity/build/Modules/UIElements/VisualTreeRepaintUpdater.cs:35)
UnityEngine.Experimental.UIElements.VisualTreeUpdater.UpdateVisualTree () (at C:/buildslave/unity/build/Modules/UIElements/VisualTreeUpdater.cs:70)
UnityEngine.Experimental.UIElements.Panel.Repaint (UnityEngine.Event e) (at C:/buildslave/unity/build/Modules/UIElements/Panel.cs:507)
UnityEngine.Experimental.UIElements.UIElementsUtility.DoDispatch (UnityEngine.Experimental.UIElements.BaseVisualElementPanel panel) (at C:/buildslave/unity/build/Modules/UIElements/UIElementsUtility.cs:230)
UnityEngine.Experimental.UIElements.UIElementsUtility.ProcessEvent (System.Int32 instanceID, System.IntPtr nativeEventPtr) (at C:/buildslave/unity/build/Modules/UIElements/UIElementsUtility.cs:68)
UnityEngine.GUIUtility.ProcessEvent (System.Int32 instanceID, System.IntPtr nativeEventPtr) (at C:/buildslave/unity/build/Modules/IMGUI/GUIUtility.cs:179)
Utilizo la ultima version unity3d 2018.3.2f1 y la ultima version de obi cloth
Edit: solucionado , Elimine la carpeta manualmente y reinstale obi cloth y se soluciono el problema.
, gracias
