Web Build error
Hi There.
I would like to use your softbody system in a web build but I get an error:
Error building Player: Shader error in 'FluidFoamCollisions': Buffer count exceeding hard limit. No known hw supports this shader. Consider combining separate buffers into one containing struct elements. at kernel SolveDiffuseContacts (on gles3)
Is this a known issue? Is there a fix?
(17-08-2026, 09:05 AM)TubbyCrumbles Wrote: Hi There.
Obi only supports platforms that the Burts compiler can compile for, and that have compute shader support.
Kind regards,
