21-10-2025, 09:18 PM
I’m writing to ask about a solution for an issue I encountered while using the Obi Rope.
When I attach the rope’s start to another object, I clearly set the start point to the object’s local (0, 0, 0). However, if the object moves strongly, or if I turn the Obi Solver off and on again, the attachment point sometimes shifts away from the specified position.
Additionally, even when only the start is fixed, the update speed of the fixed position seems quite slow while the object is moving. I suspect this happens because it’s only updated in FixedUpdate, but I wonder if there’s any way to modify this behavior.
Also, when the Obi Solver is turned off and the fixed object moves slightly, I’d like the rope to reattach to the newly specified fixed position relative to the object when the solver is turned back on. Would I need to modify the Obi Particle Attachment directly to achieve this? I think there should be an internal option to choose the update method or specify fixed local position and rotation, and it should be guaranteed to work properly.
If there’s any external function or component that can update or refresh these position and offset values dynamically, please let me know.
For now, I’d be happy if the issues mentioned above could be resolved while using the system.
Thank you very much.
