Not sure if this is a bug or my incompetance but I would appreciate some help!
I am trying to change the section of my ObiRopeRenderer at runtime. I have tried two different methods that are'nt working.
First I tried getting the ObiRopeRenderer in a script and setting the section to the new section I want. I then disabled and enabled the renderer to force an update. This worked initially but has since stopped.
My next idea was to add two renderers that are each set up with a section, and to enable one and disable the other when I wanted to change, to avoid changing the renderer. This didnt work either, the inspector shows the correct renderers each with a different section, but changing between them the section is the same.
Should this be possible?
Cheers
I was running 7.0, I upgraded to 7.1 and that seems to have fixed the problem. But now all of my particle attachments are flipped the wrong way by 180 when I use constraint orientation?! How can I fix this?
Cheers
Cheers
Cheers
