can you remove particles from a full-body volumetric softbody?
I'm trying to make a character that has natural jiggle on all the naturally jiggling body parts. However, when I don't edit the particles, the boobs don't jiggle (but everything else does). I'm trying to fix this by either removing the particles (thinking that less particles would make it less
I have two issues with FBVS:
- when ever I remove particles, the areas where I removed particles explodes when I press play:
https://ibb.co/s956L3qM
- I figured: I can't edit the body when it also uses bones so I tried I edit it first and then add the bones. This gave me the same result.
So, is there a way that I can remove particles that I don't need without things breaking on a full body volume simulation?
