Hi Obi,
we have an rabbit using obi softbody, but we want more efficiency, so we want to reduce particles in specified part, for a rabbit we just want it's ears more soft, but want to reduce other body part's particles.
we successfully deleted the particles (keep the bones particles) and updated the blueprint, but so sad when we start to run , error occured and even ai dont know why:
IndexOutOfRangeException: Reading from index 7926 is out of range of '7920' Capacity.
Obi.ObiNativeList1[T].get_Item (System.Int32 index) (at Assets/Obi/Scripts/Common/DataStructures/NativeList/ObiNativeList.cs:86)
Obi.ObiShapeMatchingConstraintsBatch.Merge (Obi.ObiActor actor, Obi.IObiConstraintsBatch other) (at Assets/Obi/Scripts/Common/Blueprints/Constraints/Batches/ObiShapeMatchingConstraintsBatch.cs:179)
Obi.ObiConstraints1[T].Merge (Obi.ObiActor actor, Obi.IObiConstraints other) (at Assets/Obi/Scripts/Common/Blueprints/Constraints/ObiConstraints.cs:58)
Obi.ObiSolver.PushConstraints () (at Assets/Obi/Scripts/Common/Solver/ObiSolver.cs:2230)
Obi.ObiSolver.StartSimulation (System.Single stepDelta, System.Int32 simulationSteps) (at Assets/Obi/Scripts/Common/Solver/ObiSolver.cs:1647)
Obi.ObiSolver.LateUpdate () (at Assets/Obi/Scripts/Common/Solver/ObiSolver.cs:1169)
the main problem is that looks like when we recreated(updated) the blueprint, something wrong in formart, or the blueprint modified after bind ??
so is it possible to make this happen, or any tips for us, especially which part of obi codes need to read ??
