Runtime generated SDF
What would be the best approach for acheiving a HD sdf collision map close to the player? I would love to reach a resolution of 1-5 centimeters (in a VR setting).
I'm working on a smooth voxel system with detailing through tesselation and displacement. Next up for me is generating this HD collsion map but I'm stumped at finding a solution here.
So far the implemented process is:
  1. Have a low resolution SDF field
  2. Generate mesh from SDF
  3. Unwrap mesh UV's and apply virtual texturing
  4. Use tesselation+displacement when rendering. It now looks HD and photorealistic!
I will have to figure out a way to make a custom SDF collider that Obi can use.
It needs to be runtime and on demand as chunks are loaded and LOD changed. I know of the method from the Unity demo team. I could likely do this or something similar, but with some virtual volume method so that i only resolve high definition close to geometry.
At some point I need to stop the flood-fill propagation of distances if nothing else at the seams between high resolution and low resolution. How mathematically accurate does the SDF need to be for Obi to work properly? Is accuracy most important close to zero or does it have to be seamless?
(10-03-2025, 09:56 PM)goosejordan Wrote: What would be the best approach for acheiving a HD sdf collision map close to the player? I would love to reach a resolution of 1-5 centimeters (in a VR setting).
Obi already has adaptive SDF support. The ObiDistanceField scriptable object class stores SDF data as a list of DFNode structs. You can create a new distance field and populate its data as you see fit.
Obi's SDFs are dual and octree-based. This means each node in the tree stores 8 distance values (one at each of its corners) instead of the usual approach of storing them in a regular grid and have distance values stored at the center of each cell. This allows them to have adaptive LOD while retaining fast trilinear interpolation (as distance data needed for interpolation is stored contiguously).
Each DFNode has these fields:
distancesA = 4 distance values at the negative face in the XY plane.
distancesB = 4 distance values at the positive face in the XY plane.
center = spatial coordinates of the center of the node.
int firstChild = index of this node's first child in the list. All 8 children are assumed to be stored consecutively, so 2nd child will be at firstChild+1, etc.
The ASDF class contains two static methods: one to build an adaptive SDF from a bounding interval hierarchy, and another one to sample it. You can use these as reference implementations.
Note SDFs are designed to be created in the CPU and stored in CPU memory. When using the Compute backend, this data is sent to the GPU. Since your distance data likely comes from the GPU, and you probably want to update the SDF often, the main hurdle will be how to efficiently perform data copying and avoid the impact of readbacks.
(10-03-2025, 09:56 PM)goosejordan Wrote: but with some virtual volume method so that i only resolve high definition close to geometry.
Obi's SDFs allow you to have varying resolution, since they're octree based (you can have as many resolution levels as you'd like).
(10-03-2025, 09:56 PM)goosejordan Wrote: At some point I need to stop the flood-fill propagation of distances if nothing else at the seams between high resolution and low resolution. How mathematically accurate does the SDF need to be for Obi to work properly? Is accuracy most important close to zero or does it have to be seamless?
Ideally, close to the zero isosurface you want to be as accurate as possible, so that collisions are smooth. No need for it to be seamless, specially when further away from the isosurface.
Wow, thanks a lot! That was very in-depth, I have a lot to work with now Sonrisa
Recently got back to this feature and I am happy to say it finally works! I required only very minor changes to the engine to integrate it.
I added this interface
public interface IExtendedColliderHandler
    public JobHandle GenerateContacts(ObiColliderWorld world,
        BurstSolverImpl solver,
        NativeList<Oni.ContactPair> contactPairs,
        NativeQueue<BurstContact> contactQueue,
        NativeArray<int> contactOffsetsPerType,
        float deltaTime,
        JobHandle inputDeps);
public class DummyExtendedColliderHandler : IExtendedColliderHandler
    public JobHandle GenerateContacts(ObiColliderWorld world, BurstSolverImpl solver, NativeList<Oni.ContactPair> contactPairs,
        NativeQueue<BurstContact> contactQueue, NativeArray<int> contactOffsetsPerType, float deltaTime, JobHandle inputDeps)
        return inputDeps;
And after every built in collider evaluation i run this:
inputDeps = extendedColliderHandler.GenerateContacts(world, solver, contactPairs, colliderContactQueue, contactOffsetsPerType, deltaTime, inputDeps);
In the awake I just added the dummy handler should the collider world init before my external code.
if (extendedColliderHandler == null) extendedColliderHandler = new DummyExtendedColliderHandler();
My collision handler has one low resolution SDF and a virtual high resolution SDF. The high resolution is requested near the camera and built from the displaced terrain mesh which is a whole topic on its own. The mesh to sdf solution is based on a project from Unity's demo team but with heavy modifications.
Check it out here! I have a video of it in action and another showing the debug visualisation:
https://drive.google.com/file/d/16UbBW6L...sp=sharing
Also, I'm wondering if I may share all this in a devlog on my Youtube channel? I'm asking permission because I want to dive pretty deep in technicals and that includes how Obi works. No code sharing of course, except maybe how I integrated with the collider world if that is okay?
Thanks again for the guidance Josemendez!
Glad to hear you got it working (and working so well)! You can of course share your journey on your Youtube channel, showing as little or as much code as you'd wish - it is not like Obi's innards contain some super secret special sauce, most of it is well known stuff that you can find online in lots of articles/papers.
Wish you the best with your project, let me know if you need help anytime.
Hello again!
I have finally completed that video I talked about Sonrisa
I talk in length about Obi Physics around 09:45
Dedo arriba
That's amazing! I quickly scrubbed trough the video but will sit down and watch it entirely this weekend as it looks very interesting. Congrats!
