Hey,
I'm getting this import error. In my previous post things worked, then I tried importing a different obi product (obi fluid) and something got corrupted causing errors that won't self-resolve.
https://imgur.com/a/ud40C13
When deleting/re-importing I keep getting this error, for either or both:
I'm not sure where it came from since I hadn't changed any core things such as adding assembly asmdef files. I did add new packages like Mathematics/Collections/Burst
Burst is version 1.8.13. Updating to 1.8.16 didn't fix it.
I am using Unity 2022.3.22f1 with Universal Render Pipeline. The error is preventing me from loading the plugin.
Assets\Obi\Scripts\Common\Backends\Burst\DataStructures\NativeMultilevelGrid.cs(74,46): error CS1061: 'UnsafeList<K>' does not contain a definition for 'length' and no accessible extension method 'length' accepting a first argument of type 'UnsafeList<K>' could be found (are you missing a using directive or an assembly reference?)I'm not sure where it came from since I hadn't changed any core things such as adding assembly asmdef files. I did add new packages like Mathematics/Collections/Burst
