Hi
I am having trouble rigging my character that has a bunch of submeshes(internal organs in this case). I manage to get other simpler meshes to work properly with softbody but something is breaking when I do it with my complex character.
Going by the "Elastic character" tutorial does not really apply as the elastic character only has one main mesh.
I will provide some screenshots. I have the default ObiSolver component on the "FemaleBody" Object. This is a medical app btw.
Threads: 28
12-04-2024, 08:42 AM
(This post was last modified: 12-04-2024, 08:43 AM by josemendez.)
(11-04-2024, 11:09 AM)JohnOrzone Wrote: Hi
Hi John,
You can only generate blueprints out of a single mesh, with one main sub mesh.
A workaround for this is to generate your blueprint out of a version of you model that has just one submesh (it is only used for generating particles and it's not going to be rendered anyway, so no point in having multiple sub meshes), then use multiple ObiSoftbodySkinners to bind all the organs to the resulting blueprint. See: http://obi.virtualmethodstudio.com/manua...inner.html
Thank you, I understand.
Is it possible to change the scale at runtime? I want to scale down a sphere until it dissapears.
Threads: 28
(18-04-2024, 11:01 AM)JohnOrzone Wrote: Thank you, I understand.
Hi John,
Unlike translation and rotation, scaling does not maintain distances between points. For this reason it can only be used on rigid objects.
You can however change the scale of the ObiSolver component, which will scale the entire simulation space down. This may or may not be enough for your use case, eg. if there's more than one actor managed by the solver they will all be scaled towards the solver's origin.
Ok thanks for quick reply!
I have some spheres in a bowl and I need to be able to make them one by one become smaller to eventually dissapear completely. Is there no way of doing this? Scaling everything at once does not work since I have to do them one at a time.
Thanks for all the support!
Threads: 28
18-04-2024, 01:12 PM
(This post was last modified: 18-04-2024, 01:50 PM by josemendez.)
(18-04-2024, 01:08 PM)JohnOrzone Wrote: Ok thanks for quick reply!
No, since changing the size of an object changes the rest distance between its particles. This requires recalculating all constraints which is a really expensive operation (done when you Generate() the blueprint, either in the editor or programmatically). Same applies to ropes, cloth, and all kinds of deformable objects.
Threads: 2
02-04-2025, 07:22 AM
(This post was last modified: 02-04-2025, 08:35 AM by aardworm.)
(12-04-2024, 08:42 AM)josemendez Wrote: Hi John,
You mean this requires baking all meshes into 1 mesh and then setting up the particles with that?
So, eyes, clothes etc. etc.
What if I want a character to have multiple clothes that they can swap at run time?
Edit: so I tried doing it. But the other objects all have a different root bone. Unsure if that matters, so I set them all the the same root bone. What happened next was that all objects became invisible except the last object. In this case, the hair was visible (and affected by ObiSoftbody, so that part worked).
What am I doing wrong?
Edit2:
also getting:
UnityEditor.Graphs.Edge.WakeUp () (at <5a50690aa5234720b2f216656322393b>:0)
UnityEditor.Graphs.Graph.DoWakeUpEdges (System.Collections.Generic.List`1[T] inEdges, System.Collections.Generic.List`1[T] ok, System.Collections.Generic.List`1[T] error, System.Boolean inEdgesUsedToBeValid) (at <5a50690aa5234720b2f216656322393b>:0)
UnityEditor.Graphs.Graph.WakeUpEdges (System.Boolean clearSlotEdges) (at <5a50690aa5234720b2f216656322393b>:0)
UnityEditor.Graphs.Graph.WakeUp (System.Boolean force) (at <5a50690aa5234720b2f216656322393b>:0)
UnityEditor.Graphs.Graph.WakeUp () (at <5a50690aa5234720b2f216656322393b>:0)
UnityEditor.Graphs.Graph.OnEnable () (at <5a50690aa5234720b2f216656322393b>:0)
Threads: 28
(02-04-2025, 07:22 AM)aardworm Wrote: You mean this requires baking all meshes into 1 mesh and then setting up the particles with that?
Correct.
(02-04-2025, 07:22 AM)aardworm Wrote: What if I want a character to have multiple clothes that they can swap at run time?
Then just keep the clothes a separate mesh and create a blueprint for each one.
Threads: 2
02-04-2025, 08:44 AM
(This post was last modified: 02-04-2025, 08:54 AM by aardworm.)
(02-04-2025, 08:07 AM)josemendez Wrote: Correct.
kind regards, Thank you for your reply! I tried doing it. But the other objects all have a different root bone. Unsure if that matters, so I set them all the the same root bone. What happened next was that all objects became invisible except the last object. In this case, the hair was visible (and affected by ObiSoftbody, so that part worked).
also getting:
Edit: error seems unrelated.
Managed to make it work, however, it doesn't work so great as both the body and clothes in my case clip into eachother (when using a single Softbody).
Threads: 28
02-04-2025, 08:59 AM
(This post was last modified: 02-04-2025, 08:59 AM by josemendez.)
(02-04-2025, 08:44 AM)aardworm Wrote: Managed to make it work, however, it doesn't work so great as both the body and clothes in my case clip into eachother (when using a single Softbody).
Not sure what your setup looks like, your mention having clothes but it seems like you're using ObiSoftbody for them?
Or are you using a ObiSofbody for the character's body and a ObiCloth on top of it? If that's the case, such a setup will be quite brittle as it will rely purely on particle-particle contacts which may suffer from tunneling as the character moves.
Could you share more details regarding what is it that you're trying to achieve?
