Threads: 21
06-04-2024, 12:10 PM
(This post was last modified: 06-04-2024, 12:38 PM by kodra.)
I'd like to disable ObiSoftbodySkinner at runtime and make the mesh deformation controlled by SkinnedMeshRenderer again, and reenable it at some condition.
The first time disabling it works. However, if I enable ObiSoftbodySkinner again after disabling it, I get this error:
Code: InvalidOperationException: The previously scheduled job BurstShapeMatchingConstraintsBatch:ShapeMatchingConstraintsBatchJob writes to the UNKNOWN_OBJECT_TYPE ShapeMatchingConstraintsBatchJob.restComs. You are trying to schedule a new job BurstShapeMatchingConstraintsBatch:ShapeMatchingCalculateRestJob, which writes to the same UNKNOWN_OBJECT_TYPE (via ShapeMatchingCalculateRestJob.restComs). To guarantee safety, you must include BurstShapeMatchingConstraintsBatch:ShapeMatchingConstraintsBatchJob as a dependency of the newly scheduled job.
Unity.Jobs.LowLevel.Unsafe.JobsUtility.ScheduleParallelFor (Unity.Jobs.LowLevel.Unsafe.JobsUtility+JobScheduleParameters& parameters, System.Int32 arrayLength, System.Int32 innerloopBatchCount) (at <cb81df0c49c643b1a04d9fc6ccca2433>:0)
Unity.Jobs.IJobParallelForExtensions.Schedule[T] (T jobData, System.Int32 arrayLength, System.Int32 innerloopBatchCount, Unity.Jobs.JobHandle dependsOn) (at <cb81df0c49c643b1a04d9fc6ccca2433>:0)
Obi.BurstShapeMatchingConstraintsBatch.CalculateRestShapeMatching () (at Assets/ThirdParty/Obi/Scripts/Common/Backends/Burst/Constraints/ShapeMatching/BurstShapeMatchingConstraintsBatch.cs:147)
Obi.ObiShapeMatchingConstraintsBatch.RecalculateRestShapeMatching () (at Assets/ThirdParty/Obi/Scripts/Common/Blueprints/Constraints/Batches/ObiShapeMatchingConstraintsBatch.cs:232)
Obi.ObiSoftbody.RecalculateRestShapeMatching () (at Assets/ThirdParty/Obi/Scripts/Softbody/Actors/ObiSoftbody.cs:194)
Obi.ObiSoftbody.UpdateParticleProperties () (at Assets/ThirdParty/Obi/Scripts/Softbody/Actors/ObiSoftbody.cs:243)
Obi.ObiSoftbodySkinner.BindBoneParticles () (at Assets/ThirdParty/Obi/Scripts/Softbody/Rendering/ObiSoftbodySkinner.cs:261)
Obi.ObiSoftbodySkinner.Softbody_OnBlueprintLoaded (Obi.ObiActor a, Obi.ObiActorBlueprint blueprint) (at Assets/ThirdParty/Obi/Scripts/Softbody/Rendering/ObiSoftbodySkinner.cs:199)
Obi.ObiSoftbodySkinner.OnEnable () (at Assets/ThirdParty/Obi/Scripts/Softbody/Rendering/ObiSoftbodySkinner.cs:130)
UnityEngine.GUIUtility:ProcessEvent(Int32, IntPtr, Boolean&)
I get this with Obi 7. I didn't test if it happens with 6.4.
Changing influence seems to be impossible either at runtime?
My guess (not a very educated one) is that it has something to do with Obi 7's new asynchronized mode. In synchronized mode this error doesn't happen. In asynchronized mode it happens sometimes.
Threads: 28
(06-04-2024, 12:10 PM)kodra Wrote: I'd like to disable ObiSoftbodySkinner at runtime and make the mesh deformation controlled by SkinnedMeshRenderer again, and reenable it at some condition.
Thanks for the report! I’ll take a look at this and get back to you.
Threads: 21
Besides this exception, I think it would be nice to be able to adjust the Softbody Influence property at runtime, so one can enable/disable the skinner smoothly (by increasing/decreasing the influence over time) rather than abruptly.
Threads: 28
I've been unable to reproduce this so far. Will try some more cases and get back to you.
Threads: 28
08-04-2024, 01:38 PM
(This post was last modified: 08-04-2024, 05:02 PM by josemendez.)
(06-04-2024, 07:55 PM)kodra Wrote: Besides this exception, I think it would be nice to be able to adjust the Softbody Influence property at runtime, so one can enable/disable the skinner smoothly (by increasing/decreasing the influence over time) rather than abruptly.
It is not possible to do this, since changing the softbody influence requires to recalculate and sort all per-vertex influences and then drop those above the desired amount of total influences per vertex. While I simplified this as lerp(skinning, simulation, influence) in another post, it doesn't actually work that way: full bone skinning and softbody skinning calculated, then their results interpolated per vertex. The reason for this is performance.
Say for instance there's a vertex that originally had 4 bone influences, with the maximum amount of influences being 4. Upon binding the softbody, there's 3 particles within the influence radius. So with a softbody influence of 1 (100%), the 4 bone influences would be dropped and only the 3 particles would have any effect, their weights calculated using the distance to the vertex and then normalized (so that all weights add up to 1). You end up with 3 influences instead of 7 (4 bones + 3 particles).
With a softbody influence of 0.5, all 4 bones and 3 particles influence the vertex, so they're sorted by weight and only the 4 having the most influence are kept, then normalized. You end up with only 4 influences, instead of 7.
With a softbody influence of 0 no particles have any influence and only bone influences are calculated, just like in a regular SkinnedMeshRenderer. Again you end up with 4 influences instead of 7.
This way the cost of the whole thing is not cost of bone skinning + cost of particle skinning: you only pay for the amount of influences actually used, for a typical speedup of x2. The downside of this is that you can't lerp between them in realtime, since the lerping parameter is "baked" into the weights.
Threads: 21
(08-04-2024, 01:38 PM)josemendez Wrote: It is not possible to do this, since changing the softbody influence requires to recalculate and sort all per-vertex influences and then drop those above the desired amount of total influences per vertex. While I simplified this as lerp(skinning, simulation, influence) in another post, it doesn't actually work that way: full bone skinning and softbody skinning calculated, then their results interpolated per vertex. The reason for this is performance.
Oh I see... that makes sense. Thank you for the answer.
I still think it might be worth it to provide this as an option for the user to use at their own risk though.
