28-04-2022, 07:40 PM
I had a quick question regarding the 'atmospheric drag' parameter in the emitter blueprints. Since this is just one editable parameter, what exactly does the variable represent? Is it the drag coefficient? Density? Surface area? Or does it represent the actual drag force – and if so, is it dependent on velocity squared? I would like to create a relatively accurate simulation through the air, and drag is a rather large factor in that.
Thanks in advance!
F17
Thanks in advance!
F17
