Hi, yes I gathered it would not be a common issue as I had a search for something similar before I posted. I'm using Unity 2019.4.0f1. Not sure how to see the Obi Rope version as it doesn't mention a version number in the 'about' window. I've tried to attach a zip file with the crash report and errors but it won't let me add it, also the same thing if I try and send you the unzipped files. How can I get these files to you?
I get an error when I change the name of a control point too, but not a crash.
Socket: connect failed, error: A non-blocking socket operation could not be completed immediately.
(10035)
UnityEditor.AssetDatabase:SaveAssets()
Obi.ObiActorBlueprint:SetParticleGroupName(Int32, String) (at Assets/ThirdParty/Obi/Scripts/Common/Blueprints/ObiActorBlueprint.cs:395)
Obi.ObiRopeBlueprintBase:ControlPointRenamed(Int32) (at Assets/ThirdParty/Obi/Scripts/RopeAndRod/Blueprints/ObiRopeBlueprintBase.cs:57)
UnityEngine.Events.UnityEvent`1:Invoke(Int32)
Obi.ObiPath:SetName(Int32, String) (at Assets/ThirdParty/Obi/Scripts/RopeAndRod/DataStructures/Path/ObiPath.cs:262)
Obi.ObiPathEditor
rawControlPointInspector() (at Assets/ThirdParty/Obi/Editor/RopeAndRod/ObiPathEditor.cs:825)
Obi.ObiPathEditor
rawUIWindow(Int32) (at Assets/ThirdParty/Obi/Editor/RopeAndRod/ObiPathEditor.cs:509)
UnityEngine.GUIUtility
rocessEvent(Int32, IntPtr)
