I am fairly new to OBI and own both Rope & Softbody - Note that i have spent a considerable amount of time to try and understand OBI Softbody.
I know you are working on more tutorials but having video of particle editing for Softbody would be of great help - Yes the tutorial guide is there but it not enough IMO as explaining to customers best practices and show different types of particles editing would be sweet - this is just some feedback so take it or leave it
The issue I am seeing is the following and I have added screenshots to help understand.
I took the deformable barrels sample and tried to edit the barrel footprint by removing 1 particle and trying to add it back - I was unsuccessful in doing so.
1) Removing top particle of barrel blueprint: (I picked an arbitrary one)
![[Image: JLOkzLD.jpg]](https://i.imgur.com/JLOkzLD.jpg)
![[Image: yBMyruA.jpg]](https://i.imgur.com/yBMyruA.jpg)
All good - the particle was removed.
I then try and add a new one back and I am doing this as I could not add particles to my own blueprint and mesh using the editor so I use the barrel one to test against.
Here is what I see when I try and paint->add some particle (render mode is particle + mesh) - particle is not added or at least it doesn't show.
![[Image: 9NDpshJ.jpg]](https://i.imgur.com/9NDpshJ.jpg)
A closer look:
![[Image: aflSKx5.jpg]](https://i.imgur.com/aflSKx5.jpg)
What am I doing wrong? I have read the guide and watch tutorials I could find and I cannot make this work after trying many things.
Thanks in advance for any help.
A closer look:
