14-08-2020, 06:14 AM
Hi, I want Render a Chain at Run Time, but I got this.
Obi.ObiRopeChainRenderer.CreateChainLinkInstances (Obi.ObiRopeBase rope) (at Assets/ThirdParty/Obi/Scripts/RopeAndRod/Rendering/ObiRopeChainRenderer.cs:98)
Obi.ObiRopeChainRenderer.UpdateRenderer (Obi.ObiActor actor) (at Assets/ThirdParty/Obi/Scripts/RopeAndRod/Rendering/ObiRopeChainRenderer.cs:116)
Obi.ObiActor.Interpolate () (at Assets/ThirdParty/Obi/Scripts/Common/Actors/ObiActor.cs:1016)
Obi.ObiSolver.Interpolate (System.Single stepTime, System.Single unsimulatedTime) (at Assets/ThirdParty/Obi/Scripts/Common/Solver/ObiSolver.cs:1351)
Obi.ObiUpdater.Interpolate (System.Single stepDeltaTime, System.Single accumulatedTime) (at Assets/ThirdParty/Obi/Scripts/Common/Updaters/ObiUpdater.cs:119)
Obi.ObiFixedUpdater.Update () (at Assets/ThirdParty/Obi/Scripts/Common/Updaters/ObiFixedUpdater.cs:79)
I don't know what's wrong.
here is My code:
thanks for the help.
here is My code:
using System.Collections;
using UnityEngine;
using Obi;
public class HookTool : MonoBehaviour
public ObiSolver solver;
public ObiCollider character;
public float hookExtendRetractSpeed = 2;
public bool canTear;
public ObiRopeSection section;
//public GameObject chain;
private List<GameObject> PrefabsList;
ObiRope rope;
private ObiRopeBlueprint blueprint;
private ObiRopeExtrudedRenderer ropeRenderer;
private ObiRopeChainRenderer chainRenderer;
private ObiRopeCursor cursor;
KeyCode interKey = KeyCode.Joystick1Button0;
KeyCode addRope = KeyCode.Joystick1Button4;
KeyCode lessRope = KeyCode.Joystick1Button5;
private bool attached = false;
private GameObject maincam;
private bool doOnce;
private SpeedTutorInspectSystem.ObjectController raycastedObj;
RaycastHit hit;
void Awake()
//找到玩家身上的主攝像機
GameObject camobject = GameObject.FindGameObjectWithTag("MainCamera");
maincam = camobject;
//這裡學到一個超牛的,之前我沒有給chain初始化,public GameObject chain並沒有定義,下面必須初始化,否則後面的一切,update都不會觸發!
PrefabsList = new List<GameObject>();
//GameObject instance = Instantiate(Resources.Load("ChainLinkRed", typeof(GameObject))) as GameObject;
GameObject instance = Resources.Load("ChainLinkRed", typeof(GameObject)) as GameObject;
PrefabsList.Add(instance);
// Create both the rope and the solver:
rope = gameObject.AddComponent<ObiRope>();
chainRenderer = gameObject.AddComponent<ObiRopeChainRenderer>();
chainRenderer.linkPrefabs = PrefabsList;
chainRenderer.linkScale = new Vector3(34,34,34);
chainRenderer.twistAnchor = 0;
chainRenderer.sectionTwist = 70;
// Setup a blueprint for the rope:
blueprint = ScriptableObject.CreateInstance<ObiRopeBlueprint>();
blueprint.resolution = 0.5f;
// Tweak rope parameters:
rope.maxBending = 0.02f;
// Add a cursor to be able to change rope length:
cursor = rope.gameObject.AddComponent<ObiRopeCursor>();
cursor.cursorMu = 0;
cursor.direction = true;
private void OnDestroy()
DestroyImmediate(blueprint);
public void LaunchHook()
//以後都是從整個class讀取ray
hit = maincam.GetComponent<SpeedTutorInspectSystem.InspectionRaycast>().hit;
if (hit.collider.CompareTag("InteractObject"))
//Debug.Log("hit" + hit.collider.gameObject.name);
StartCoroutine(AttachHook());
//yield
chainRenderer.enabled = true;
chainRenderer.twistAnchor = 0.2f;
private IEnumerator AttachHook()
//Debug.Log("hook begin");
yield return 0;
Vector3 localHit = rope.transform.InverseTransformPoint(hit.point);
// 將rope由兩點畫出來:
blueprint.path.Clear();
blueprint.path.AddControlPoint(Vector3.zero, -localHit.normalized, localHit.normalized, Vector3.up, 0.1f, 0.1f, 1, 1, Color.white, "Hook start");
blueprint.path.AddControlPoint(localHit, -localHit.normalized, localHit.normalized, Vector3.up, 0.1f, 0.1f, 1, 1, Color.white, "Hook end");
blueprint.path.FlushEvents();
// 畫出rope的blueprint:
yield return blueprint.Generate();
// 設置兩點的交互,rope對物體的影響在這裡設置:
var pinConstraints = blueprint.GetConstraintsByType(Oni.ConstraintType.Pin) as ObiConstraints<ObiPinConstraintsBatch>;
var batch = pinConstraints.batches[0];
batch.AddConstraint(0, character, transform.localPosition, Quaternion.identity);
batch.AddConstraint(blueprint.activeParticleCount - 1, hit.collider.GetComponent<ObiColliderBase>(),
hit.collider.transform.InverseTransformPoint(hit.point), Quaternion.identity);
// 最終顯示出來.
rope.tearingEnabled = canTear;
rope.selfCollisions = true;
// 這裡是讓物理正常
pinConstraints = rope.GetConstraintsByType(Oni.ConstraintType.Pin) as ObiConstraints<ObiPinConstraintsBatch>;
batch.stiffnesses[0 * 2 + 1] = 10000;
batch.stiffnesses[1 * 2 + 1] = 10000;
//rope.GetComponent<ObiRopeChainRenderer>().enabled = true;
//chainRenderer.twistAnchor = 0.1f;
public void DetachHook()
// Set the rope blueprint to null (automatically removes the previous blueprint from the solver, if any).
rope.ropeBlueprint = null;
chainRenderer.enabled = false;
//rope.GetComponent<ObiRopeChainRenderer>().enabled = false;
void Update()
//如果用getkey的話就會一秒內按無數次,必須是Getkeydown才可以!gfg
if (Input.GetKeyDown(interKey))
if (!rope.isLoaded)
LaunchHook();
else
DetachHook();
if (rope.isLoaded)
if (Input.GetKey(lessRope))
cursor.ChangeLength(rope.restLength - hookExtendRetractSpeed * Time.deltaTime);
if (Input.GetKey(addRope))
cursor.ChangeLength(rope.restLength + hookExtendRetractSpeed * Time.deltaTime);
if (Input.GetKeyDown(KeyCode.P))
//chainRenderer.enabled = true;
chainRenderer.twistAnchor += 0.1f;
//chainRenderer.gameObject.SetActive(true);
