01-12-2019, 12:24 AM
I just bought Obi Cloth and tried to install it on my current project (2020.1.0a12, HDRP, Win64) and I get the following error messages :
Launching a scene anyway result in :
Compiler doesn't seem to be finding any problem in the source code, so I guess something is wrong with some of the provided DLLs (the "libOni.dll" for both x86 and x86_64 don't seem to have any problems so I'm out of ideas).
I got Obi Cloth to run without fuss on an older 2019.3-ish project, so I'm not sure what exactly is wrong with my 2020 ones.
Importing this Asset does 'cause Unity 2020 to crash, and crash again at least one more time when reloaded, before letting the project finally load - but still with the errors mentioned above.
Thanks for your help.
Quote:Error: Could not load signature of Obi.ObiClothBlueprintEditor:get_clothBlueprint due to: Could not load file or assembly 'ObiTried to reload Unity multiple time as the FAQ suggest, but it didn't change anything.
Error: Could not load signature of ColliderHighlighter:Solver_OnCollision due to: Could not load file or assembly 'Obi
Unloading broken assembly Library/ScriptAssemblies/Assembly-CSharp-Editor.dll, this assembly can cause crashes in the runtime
Unloading broken assembly Library/ScriptAssemblies/Assembly-CSharp.dll, this assembly can cause crashes in the runtime
Couldn't find a readme (yes, this one is an actual message)
Quote:Assembly 'Library/ScriptAssemblies/Assembly-CSharp.dll' will not be loaded due to errors:Unable to resolve reference 'Obi'.... and a bunch of warning about pretty much every script in the sample scenes being missing (with the editor showing the usual "associated script can not be loaded").
Assembly 'Library/ScriptAssemblies/Assembly-CSharp-Editor.dll' will not be loaded due to errors:Unable to resolve reference 'Obi'.
