19-06-2019, 01:25 AM
Hello, I've got a problem with Obi Fluid, especially with emitting a tiny track of fluid.
Main problem is that I can't set emitter radius as small as I'd like to. When I reset all scripts or add new emitter, solver etc., it works perfectly fine.
But ... when I start decreasing radius of Emitter Shape Disk, it starts to throw particles around or particles become invisible. I also tried to change params as resolution in ObiEmitterMaterial or Radius Scale in Obi Particle Renderer. Even rescaling emmiter by transform didn't work well.
I noticed that by changing value in params I mentioned before, spourt of fluid becomes drops which are emitted separately.
Any idea how to create tiny track of fluid ? Thank you, in advance, for answer.
