These are changes I made to determine where a Rope particle hit a Unity Collider in 3.2.
If someone has better solution please chime in!
To get ObiRope = pa.actor
To get index of Particle = pa.indexInActor,
To get collision point of Collider = collider.transform.InverseTransformPoint(contact.point));
(I use the above to Pin particle to object that was collided with)
To get ObiCollider = collider.gameObject.GetComponent<ObiCollider>();
*EDIT* Just noticed that niZmo's code works for 3.2 as well. You can find a complete solution here: ObiRope 3.2+ and VRTK 3.3.0 alpha+
void Solver_OnCollision(object sender, Obi.ObiSolver.ObiCollisionEventArgs e)
if (contact.distance < 0.01)
//Collider collider = solver.colliderGroup.colliders[contact.other]; **Obi 3.1
Collider collider = ObiCollider.idToCollider[contact.other] as Collider;
ObiSolver.ParticleInActor pa = solver.particleToActor[contact.particle];To get ObiRope = pa.actor
