13-05-2019, 11:54 AM
first time using obi cloth.
I follow the tutorials on the website. But I always get stuck after initialising my cloth. When I click on Edit Particules I just get a bunch of errors (I listed the major ones). I try with different meshes but it never worked. I have unity 2019.1 and Obi 4.1.
__NullReferenceException: Object reference not set to an instance of an object
__The serializedObject should not be used inside OnSceneGUI or OnPreviewGUI. Use the target property directly instead. UnityEngine.GUIUtility
rocessEvent(Int32, IntPtr)
__The targets array should not be used inside OnSceneGUI or OnPreviewGUI. Use the single target property instead.
