Attaching a child gameobject to a gameobject pinned to a rope
I have a crane with a hook pinned to two obiropes. That's working fine, but I'm having a real problem when the crane hook "picks up" a different game object. If the game starts with the hook parented to a gameobject, everything is fine:
[Image: SA7eNMC.gif]
but if I use the script to parent it while the game is running it behaves very oddly:
[Image: qWBEDmU.gif]
Any idea what I am doing wrong?
(09-05-2019, 03:48 PM)nigelkennington Wrote: Hi,
Tested in the Crane sample scene, but can't reproduce anything strange. Programmatically parenting to a pinned object works just fine for me. Can you share the code you're using to parent the second object?
(09-05-2019, 04:02 PM)josemendez Wrote: Hi there,
Thanks Jose,
Here's the code:
   private void OnTriggerStay(Collider other)
       print("Got a collision with " + other.gameObject.name);
       if (other.gameObject.tag == "LiftPoint")
           if (Vector3.Distance(transform.position, other.gameObject.transform.position) < connectDistance)
               print("Got one! " + other.gameObject.name + " is touching " + this);
               if (remainingConnectTime > 0)
                   // Countdown remaining time
                   remainingConnectTime -= Time.deltaTime;
                   print ("Counting down! " + remainingConnectTime);
               else
                   print("Connecting!");
                   // Connect, disable attachpoint, reset timer
                   remainingConnectTime = connectTime;
                   other.gameObject.transform.parent.parent = this.transform.Find("LoadAnchor");
                   other.gameObject.SetActive(false);
           else
               print("Resetting to " + connectTime + " :-(");
All it's doing is counting down 3 seconds if the hook is inside the attachpoint, then setting the attachpoint's parent's parent to be the anchor of the hook and disabling the attachpoint.
(09-05-2019, 04:20 PM)nigelkennington Wrote: Thanks Jose,
Here's the code:
I've taken the rigidbody off the child object and that seems to have fixed it.
Thanks for trying to help though!
(09-05-2019, 04:20 PM)nigelkennington Wrote: I've taken the rigidbody off the child object and that seems to have fixed it.
Glad you figured it out!
Parenting a rigidbody to another rigidbody does not make sense, regardless of it being pinned to a rope or not:
https://answers.unity.com/questions/6249...idbod.html
In newer Unity versions it *can* be done, but gravity will still affect the child rigidbody in world space, making it pretty much useless. Establishing spatial relationships between rigidbodies should always be done via joints.
