08-07-2020, 11:35 AM
I tried using Obi Fluid in my VR project, but i encounter quite big issue with moving my mug around with VR Controllers. When i try to fastly rotate my mug, the fluid inside is getting out through it's side. Mug got Mesh Collider on it, i tried with distance fields, i've tried to increase thickness of Obi Collider to, but with no success.
I'm sure i move my object with velocity, angular velocity goes up to 7-8, and its when the problem occurs.
Can you give me a hand with that?
Thanks
Thanks
