Hi
I just purchased Obi Fluid from assetstore, and later realized the version 5.0 requires Unity 2019.xx.
After importing the package, I get only one error: "Assembly has reference to non-existent assembly 'GUID:15fc0a57446b3144c949da3e2b9737a9' (Assets/Obi/Scripts/Obi.asmdef)"
Can I use this version in Unity 2018.3.xx, or how can I get an older version?
Thank you
26-11-2019, 09:51 AM
(This post was last modified: 26-11-2019, 09:52 AM by josemendez.)
(26-11-2019, 09:19 AM)hdriver Wrote: Hi
Thank you
We had to switch to 2019.2 because of backwards-compatibility breaking changes introduced by Unity. It was that, or getting stuck in 2018.X forever  . We can't support both 2018 and 2019 with a single Obi version.
So 4.X works in versions up to 2019.1, 5.X in 2019.2 and up. If you need a previous version (3.X, 4.X) write to our support email (support(at)virtualmethodstudio.com) and I'll gladly make it available to you.
(26-11-2019, 09:51 AM)josemendez Wrote: Hi there,
I sent an email to support with my assetstore order details.
Sent you 4.1 in response to your email
Hi Jose Mendez,
My company have purchased obi rope plugin but it is not working on 2018.4.5. I need the correct version to make pipes and ropes.
What information do you need from me to send compatible version, Please tell. Thanks
04-01-2021, 10:33 AM
(This post was last modified: 04-01-2021, 10:35 AM by josemendez.)
(04-01-2021, 10:26 AM)zain99 Wrote: Hi Jose Mendez,
As stated in the store, the minimal supported version for Obi 5.X is Unity 2019.3.
Latest version compatible with Unity 2018.4 is Obi 4.1. Keep in mind that 4.X and 5.X are very different performance, API, and workflow wise. I'd advise to update Unity instead. In addition to this, Obi 4.1 will no longer be updated/supported once Unity drops support for 2018.4 LTS, which will happen in spring 2021.
If you need Obi 4.1, just drop us a line to support(at)virtualmethodstudio.com. Thanks!
(04-01-2021, 10:33 AM)josemendez Wrote: As stated in the store, the minimal supported version for Obi 5.X is Unity 2019.3.
Okay I will be needing 4.1 version. I have dropped an email please check it.
Thanks
Hi jose mendez,
I had mailed you twice yesterday and again I have dropped an email with invoice and purchasing detail now.
Please check whether you are receiving any mails or not.
(05-01-2021, 04:22 PM)zain99 Wrote: Hi jose mendez,
Haven’t received any emails from you. Double check the address is correct:
support (at) virtualmethodstudio.com
Looking for your emails, found out both had been flagged as spam by Gmail. Not sure of the reason, but thought you might want to know in case more recipients have the same issue.
Just sent you Obi 4.1 in response to your email. Let me know if I can be of any help.
