I have a character that I would like to add softbody physics to.
I followed the Character Softbodies tutorial, ( http://obi.virtualmethodstudio.com/manua...tbody.html). However, the character mesh would not render until I set it's "rig" import setting to None.
After that, the character could be skinned to a softbody, and it simulated just fine.
Obviously, this is not ideal because I need to animate the character. What could be the issue here?
(30-06-2023, 08:42 PM)BiffThomson Wrote: I have a character that I would like to add softbody physics to.
I followed the Character Softbodies tutorial, (http://obi.virtualmethodstudio.com/manua...tbody.html). However, the character mesh would not render until I set it's "rig" import setting to None.
Hi Biff,
Hard to say without taking a look at how you've set up the character softbody.
- Did you select the skeleton root bone in the softbody blueprint editor?
- Do skeleton particles show up correctly in the softbody blueprint editor?
See "skeleton sampling" in :http://obi.virtualmethodstudio.com/manual/6.3/softbodysetup.html
(03-07-2023, 03:18 PM)josemendez Wrote: Hi Biff,
kind regards, - Did you select the skeleton root bone in the softbody blueprint editor?
I did select a skeleton root bone in the blueprint editor. The skeleton itself shows up as lines when I enable its rendering option. However, when I click "Generate", no particles are generated at all and the Unity console starts to spam errors. (I would post an image but it won't let me.)
Unity is version 2022.3.4f1
Obi Softbody is 6.5.2
I wasnt aware I needed bone + muscle/fat particles, I'm just trying to have selective soft body physics on a character (like the rubber arms demo). 1
(03-07-2023, 10:20 PM)BiffThomson Wrote: However, when I click "Generate", no particles are generated at all and the Unity console starts to spam errors. (I would post an image but it won't let me.)
Could you just copy/paste the error text (instead of a screenshot)?
(03-07-2023, 10:20 PM)BiffThomson Wrote: I wasnt aware I needed bone + muscle/fat particles, I'm just trying to have selective soft body physics on a character (like the rubber arms demo). 1
Since you mentioned there were problems when importing a rig, I assumed you were going for a full-body softbody setup. You can generate a blueprint out of the mesh only, and it should still work fine.
(04-07-2023, 09:35 AM)josemendez Wrote: Could you just copy/paste the error text (instead of a screenshot)?
This is what the console spews when I generate with a skeleton selected.
Code: NullReferenceException: Object reference not set to an instance of an object
Obi.ObiBrushBase.DoBrush (UnityEngine.Vector3[] positions) (at Assets/Obi/Editor/Common/Blueprints/Brushes/ObiBrushBase.cs:117)
Obi.ObiParticleSelectionEditorTool.OnSceneGUI (UnityEditor.SceneView sceneView) (at Assets/Obi/Editor/Common/Blueprints/BlueprintEditorTools/ObiParticleSelectionEditorTool.cs:299)
Obi.ObiActorBlueprintEditor.OnSceneGUI (UnityEditor.SceneView sceneView) (at Assets/Obi/Editor/Common/Blueprints/ObiActorBlueprintEditor.cs:347)
UnityEditor.SceneView.CallOnSceneGUI () (at /home/bokken/build/output/unity/unity/Editor/Mono/SceneView/SceneView.cs:3807)
UnityEditor.SceneView.HandleSelectionAndOnSceneGUI () (at /home/bokken/build/output/unity/unity/Editor/Mono/SceneView/SceneView.cs:2817)
UnityEditor.SceneView.DoOnGUI () (at /home/bokken/build/output/unity/unity/Editor/Mono/SceneView/SceneView.cs:2485)
UnityEditor.SceneView.OnSceneGUI () (at /home/bokken/build/output/unity/unity/Editor/Mono/SceneView/SceneView.cs:2325)
UnityEngine.UIElements.IMGUIContainer.DoOnGUI (UnityEngine.Event evt, UnityEngine.Matrix4x4 parentTransform, UnityEngine.Rect clippingRect, System.Boolean isComputingLayout, UnityEngine.Rect layoutSize, System.Action onGUIHandler, System.Boolean canAffectFocus) (at /home/bokken/build/output/unity/unity/ModuleOverrides/com.unity.ui/Core/IMGUIContainer.cs:355)
UnityEngine.GUIUtility:ProcessEvent(Int32, IntPtr, Boolean&) (at /home/bokken/build/output/unity/unity/Modules/IMGUI/GUIUtility.cs:190)
GUI Error: You are pushing more GUIClips than you are popping. Make sure they are balanced.
UnityEngine.GUIUtility:ProcessEvent (int,intptr,bool&) (at /home/bokken/build/output/unity/unity/Modules/IMGUI/GUIUtility.cs:190)
Obi.ObiActorBlueprintEditor.UpdateTintColor () (at Assets/Obi/Editor/Common/Blueprints/ObiActorBlueprintEditor.cs:357)
Obi.ObiSoftbodySurfaceBlueprintEditor.UpdateTintColor () (at Assets/Obi/Editor/Softbody/Blueprints/ObiSoftbodySurfaceBlueprintEditor.cs:267)
Obi.ObiActorBlueprintEditor.OnSceneGUI (UnityEditor.SceneView sceneView) (at Assets/Obi/Editor/Common/Blueprints/ObiActorBlueprintEditor.cs:339)
UnityEngine.UIElements.IMGUIContainer.DoOnGUI (UnityEngine.Event evt, UnityEngine.Matrix4x4 parentTransform, UnityEngine.Rect clippingRect, System.Boolean isComputingLayout, UnityEngine.Rect layoutSize, System.Action onGUIHandler, System.Boolean canAffectFocus) (at /home/bokken/build/output/unity/unity/ModuleOverrides/com.unity.ui/Core/IMGUIContainer.cs:376)
UnityEngine.UIElements.IMGUIContainer.HandleIMGUIEvent (UnityEngine.Event e, UnityEngine.Matrix4x4 worldTransform, UnityEngine.Rect clippingRect, System.Action onGUIHandler, System.Boolean canAffectFocus) (at /home/bokken/build/output/unity/unity/ModuleOverrides/com.unity.ui/Core/IMGUIContainer.cs:676)
UnityEngine.UIElements.IMGUIContainer.DoIMGUIRepaint () (at /home/bokken/build/output/unity/unity/ModuleOverrides/com.unity.ui/Core/IMGUIContainer.cs:536)
UnityEngine.UIElements.UIR.RenderChainCommand.ExecuteNonDrawMesh (UnityEngine.UIElements.UIR.DrawParams drawParams, System.Single pixelsPerPoint, System.Exception& immediateException) (at /home/bokken/build/output/unity/unity/ModuleOverrides/com.unity.ui/Core/Renderer/UIRenderer/UIRenderers.cs:130)
Rethrow as ImmediateModeException
UnityEngine.UIElements.UIR.RenderChain.Render () (at /home/bokken/build/output/unity/unity/ModuleOverrides/com.unity.ui/Core/Renderer/UIRRenderChain.cs:519)
UnityEngine.UIElements.UIRRepaintUpdater.Update () (at /home/bokken/build/output/unity/unity/ModuleOverrides/com.unity.ui/Core/Renderer/UIRRepaintUpdater.cs:79)
UnityEngine.UIElements.VisualTreeUpdater.UpdateVisualTreePhase (UnityEngine.UIElements.VisualTreeUpdatePhase phase) (at /home/bokken/build/output/unity/unity/ModuleOverrides/com.unity.ui/Core/VisualTreeUpdater.cs:111)
UnityEngine.UIElements.Panel.UpdateForRepaint () (at /home/bokken/build/output/unity/unity/ModuleOverrides/com.unity.ui/Core/Panel.cs:1026)
UnityEngine.UIElements.Panel.Repaint (UnityEngine.Event e) (at /home/bokken/build/output/unity/unity/ModuleOverrides/com.unity.ui/Core/Panel.cs:1087)
UnityEngine.UIElements.UIElementsUtility.DoDispatch (UnityEngine.UIElements.BaseVisualElementPanel panel) (at /home/bokken/build/output/unity/unity/ModuleOverrides/com.unity.ui/Core/UIElementsUtility.cs:454)
UnityEngine.UIElements.UIElementsUtility.UnityEngine.UIElements.IUIElementsUtility.ProcessEvent (System.Int32 instanceID, System.IntPtr nativeEventPtr, System.Boolean& eventHandled) (at /home/bokken/build/output/unity/unity/ModuleOverrides/com.unity.ui/Core/UIElementsUtility.cs:205)
UnityEngine.UIElements.UIEventRegistration.ProcessEvent (System.Int32 instanceID, System.IntPtr nativeEventPtr) (at /home/bokken/build/output/unity/unity/ModuleOverrides/com.unity.ui/Core/UIElementsUtility.cs:74)
UnityEngine.UIElements.UIEventRegistration+<>c.<.cctor>b__1_2 (System.Int32 i, System.IntPtr ptr) (at /home/bokken/build/output/unity/unity/ModuleOverrides/com.unity.ui/Core/UIElementsUtility.cs:28)
UnityEngine.GUIUtility.ProcessEvent (System.Int32 instanceID, System.IntPtr nativeEventPtr, System.Boolean& result) (at /home/bokken/build/output/unity/unity/Modules/IMGUI/GUIUtility.cs:190)
Again, I'm just trying to replicate the rubber arms demo.
05-07-2023, 07:31 AM
(This post was last modified: 05-07-2023, 07:31 AM by josemendez.)
(04-07-2023, 09:37 PM)BiffThomson Wrote: This is what the console spews when I generate with a skeleton selected.
That's strange, I'm unable to reproduce this issue. Seems like the editor's GUI state is broken. Do you have any other installed assets that modify/work with the editor's UI?
You could you try resetting the editor layout: Window->Layouts->Reset All Layouts.
If this fails, would it be possible to send your project over to support(at)virtualmethodstudio.com so that I can take a closer look? thanks!
(05-07-2023, 07:31 AM)josemendez Wrote: Hi,
I've emailed a link to download the project to the provided address. I don't have anything else in this project other than what comes with the standard 3D template, the requirements for Obi Softbody (Burst, Mathematics, Jobs, Collections), and my character model.
(05-07-2023, 09:43 PM)BiffThomson Wrote: I've emailed a link to download the project to the provided address. I don't have anything else in this project other than what comes with the standard 3D template, the requirements for Obi Softbody (Burst, Mathematics, Jobs, Collections), and my character model.
Hi Biff,
Haven't received any emails from you to support(at)virtualmethodstudio.com. Could you please double check that it's been sent?
(06-07-2023, 10:07 AM)josemendez Wrote: Hi Biff,
I've definitely sent it, maybe it got caught in the spam filter? I couldn't post images last time because it said my email was a spam domain.
(07-07-2023, 02:14 AM)BiffThomson Wrote: I've definitely sent it, maybe it got caught in the spam filter? I couldn't post images last time because it said my email was a spam domain.
Double checked and checked the spam folder as well, but seems we didn’t receive it.
Just to make sure, you did use the “@“ character in place of “(at)” in the address right?
try hello(at)virtualmethodstudio.com as well, in case the support one isn’t working for some reason.
Kind regards,
