Collisions pass through mesh colliders - Printable Version +- Obi Official Forum (https://obi.virtualmethodstudio.com/forum) +-- Forum: Obi Users Category (https://obi.virtualmethodstudio.com/forum/forum-1.html) +--- Forum: Obi Softbody (https://obi.virtualmethodstudio.com/forum/forum-12.html) +--- Thread: Collisions pass through mesh colliders (/thread-4664.html) |
Collisions pass through mesh colliders - TubbyCrumbles - 18-10-2026 I have a softbody object which is acting like a balloon for my project and it collides with the ground when it is under inflated. When the softbody is deflated I add external forces to flatten it out a bit on the ground. This all works great and looks great. Problem is if I replace the collider under the softbody from a box to a mesh then no matter how thick I make the mesh collider the particles of the softbody will either pass through the collider or get stuck inside it. Is there some setting to fix this? |
