Help Simple Collision Debug Log - Printable Version +- Obi Official Forum (https://obi.virtualmethodstudio.com/forum) +-- Forum: Obi Users Category (https://obi.virtualmethodstudio.com/forum/forum-1.html) +--- Forum: Obi Fluid (https://obi.virtualmethodstudio.com/forum/forum-3.html) +--- Thread: Help Simple Collision Debug Log (/thread-4586.html) |
Simple Collision Debug Log - PortableAnswers - 25-01-2026 Hello, I am able to make fluid collide with 3D objects using the Obi Colliders, but I have yet to figure out how to get any data back from the collision itself. Even just a Debug.Log("Foo") would be enough to get me in the right direction. Here's the code snippet in the documentation that I first started messing around with: Code: ObiColliderBase collider = ObiColliderWorld.GetInstance().colliderHandles[contact.bodyB].owner;Any step-by-step instructions would be great. Thanks! RE: Simple Collision Debug Log - josemendez - 26-01-2026 (25-01-2026, 05:38 PM)PortableAnswers Wrote: Here's the code snippet in the documentation that I first started messing around with: Hi! Assuming you're just using that one line of code, all it does is retrieve a reference to a collider. You're not subscribing to the contact callback event, and not checking any contacts. Try the full snippet: Code: using UnityEngine;let me know if you need further help, kind regards |
