Help How to let Rod not streching part of the mesh - Printable Version
+--- Thread: Help How to let Rod not streching part of the mesh (/thread-4575.html)
How to let Rod not streching part of the mesh - chenji - 30-11-2025
I have a Obi rod with uses Obi rod mesh renderer. The rod contains two parts: handle and body. There are lots of type of this rod and the only difference is the length of the rod body, the handle mesh are same in these different types. As Obi rod mesh renderer only takes one mesh and will streching all the mesh for the specified rod length, now I have to make lots of meshes to get what I need. Is there any trick to only use one mesh (or two split mesh for handle and body), let Obi rod strech only the body part of the rod mesh, and let the whole rod's physics behavior controlled by Obi rod?
RE: How to let Rod not streching part of the mesh - chenji - 07-12-2025
Hello any insights on this? Any suggestions are welcome!
RE: How to let Rod not streching part of the mesh - josemendez - 07-12-2025
(07-12-2025, 05:04 AM)chenji Wrote: Hello any insights on this? Any suggestions are welcome!
My approach to this would be to simply modify the rod meshes procedurally. This allows you to have a single mesh for all your rods and simply select the length you wish the rod to have.
If your fishing rod meshes are straightened along an axis (Y for instamce), this is very simple: just pick all the vertices above a specific Y coordinate (leaving out those below, belonging to the handle) and move them further/closer apart along the axis before feeding the mesh to the rod renderer.
RE: How to let Rod not streching part of the mesh - chenji - 08-12-2025
(07-12-2025, 12:40 PM)josemendez Wrote: Hi!
Thanks for reply! I'll try this!
